Removing the rear brake calipers
Fushion_Julz
Two 19mm (IIRC) bolts to the hub
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Taylor325i
- Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Fushion_Julz wrote:Two 19mm (IIRC) bolts to the hub
These hold on the caliper bracket. 2 x 7mm hex slide bolts hold the caliper to the bracket - remove these first and the caliper should come away with the pads still in the caliper.
Taylor.
yeah you can or a local motor traders. its not cheap but that stuff will be on most of my nuts and bolts on the car. good for the next time they have to come off.
as for the 'be careful' bit from me......i was not being daddy and telling you to be careful, you still need to get one foot on the dics and two hands on the spanner / beaker bar
Fushion_Julz
The caliper will be free...along with the carrier...if you undo the 19mm bolts and (as Fuzzy points out) the flexi pipe....
Before you do, though, slacken off the bleed nipple and push back the pads from the disc....
If your disc is old, it may well have a small lip that will make it a bit hard to pull of the caliper with the pads and it is a PITA to push back the pistons with the caliper loose!
