dash clocks
bodger
Wed Feb 20, 2008 6:58 pm
my clocks are giving out strange readings, the fuel wobbles when you rev the car, the temp stays on cold and also wobbles when revved, the warning light on the dash keeps coming on and going off again and there is no fluids low in the engine, and just now the green inspection light were flashing for no apparant reason, somebody help please :cry:
Stan0870
Wed Feb 20, 2008 7:52 pm
hello mate, the clocks in your dash are powered by an idependant battery on what they call an si board,it maybe that the battery is failing,try to beg borrow or steal (not litrally) a set of clocks to try prior to buying a new one as they were 90quid without fitting the last time i priced one.. hope that helps
eko
Old timer
Wed Feb 20, 2008 8:10 pm
Sounds like knackered si board batterys.
Got a good working set of clocks here if you decide to go that route!
Wed Feb 20, 2008 8:31 pm
would they be some 6-pot clocks Tony? winkeye
eko
Old timer
Wed Feb 20, 2008 9:35 pm
E30BeemerLad wrote:would they be some 6-pot clocks Tony? winkeye
They are mate yes :D
2nd in line after Bodger for them?
bodger
Wed Feb 20, 2008 9:40 pm
dont worry eko my local breakers got some so e30beemerlad can have 1st dibs, cheers anyway
eko
Old timer
Wed Feb 20, 2008 9:52 pm
bodger wrote:dont worry eko my local breakers got some so e30beemerlad can have 1st dibs, cheers anyway
No problem mate but just to stay on topic it does sound like your si board at fault :wink:
Lee PM me if you want the clocks mate :wink:
Wed Feb 20, 2008 10:52 pm
All E30 clusters (except early and M3 ones) are interchangeable, as long as you keep your original coding plug, on the front. The only difference might be a slight difference in the red line position on the tacho.
