M3 Smoked Headlights
Kamran
Thu Jul 05, 2007 10:43 pm
I'm considering buying some M3 smoked headlights but have a Sport, are they suitable for a right hand drive motor or can they be converted. If so is it straight forward or would you guys not recomend it.
maxfield
They will fit. And should be suited for UK roads assuming they are on UK ebay, and won't be no difference to LHD cars.
Kos
Thu Jul 05, 2007 10:48 pm
maxfield wrote:They will fit. And should be suited for UK roads assuming they are on UK ebay, and won't be no difference to LHD cars.
sorry J, wrong
genuine hellas are for LHD only, the lens will shine to on coming traffic and are an MOT failure
are for converting them, its tedious but can be done
www.pukardesigns.com
IG Pukar.Designs
maxfield
Thu Jul 05, 2007 10:51 pm
Ah right never knew that, still you can change them so all is not lost.
Kamran
Thu Jul 05, 2007 10:55 pm
Kos how tedious mate, Is it worth it or is it a pain in the backside. I've heard some fella sells converted lights up north somewhere. Would it be better to buy a set of these rather than a new set of hellas which I'm gonna take apart anyway?
Templ8e30
Fri Jul 06, 2007 3:14 pm
Do you mean smoked hella headlights as per my sig ?
You just undo the 3 screws at the back of the lamps and rotate the projector unit same as all other E30's with the projector/smiley lamps.
I have a set of smoked hella's that were lhd but now throw the beam the correct way for rhd.
E30's didn't have smoked lights from the factory anyway ?
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Kos
Fri Jul 06, 2007 3:26 pm
Templ8e30 wrote:Do you mean smoked hella headlights as per my sig ?
Cheers,
Iain T
the glass lense is different ir
IG Pukar.Designs
Simon
Fri Jul 06, 2007 4:46 pm
sorry J, wrong
I've got genuine smoked hellas, and they kick the correct way.
And they are adjustable.
Kos
Fri Jul 06, 2007 8:06 pm
Simon wrote:
sorry J, wrong
want to sell them ?? winkeye
IG Pukar.Designs
Templ8e30
Fri Jul 06, 2007 10:19 pm
The smoked hella glass is different but the backs are the same as standard units in so far as they will adjust, they're actually the same part number as E34 units.
Cheers,
Iain T
Kamran
Sat Jul 07, 2007 3:05 pm
Thanks for the info guys, I think I might just make that purchase now. :D
