4 stud to 5 stud conversion
- KINGOFSNAKE
can i change my e30 325i wheel thingys to accept my five stud e36 330 18" wheels, please make any answers simple because im still learning
- Brianmoooore
Simple answer is fit M3 E30 suspension.
dasparkybad
Thats only a simple answer if you can find some e30 m3 suspension
http://lukasmotors.com/m_roadster_5_lug_swap.htm
the guy in the link used z3m parts you can also use e36 front legs and e36 compact rear trailing arms for this conversion which are a lot easier to find at a breakers yard hope this helps
- KINGOFSNAKE
cheers , any help is appreciated. the m3 option sounds expensive, but you never know
sidewaysjon
would this not be easier and cheaper, a lot cheaper
http://cgi.ebay.com/ebaymotors/BMW-4-LU ... enameZWDVW
sideways is the new way forward
- KINGOFSNAKE
thanx for all the replies, my suspensions shagged so ive got to change it, and my e36 (which i dont like that much)
has these beautiful wheels on from bmw almost alpina style so i would like to keep them. the convertor mentioned
by sideways jon sounds perfect. if you listen carefully you can hear me reaching for my tape measure to see if that way is possible
- Brianmoooore
it's your neck you'll be risking (plus those of the odd pedestrian and other motorist).sidewaysjon wrote:would this not be easier and cheaper, a lot cheaper
- KINGOFSNAKE
not quite sure what the last message meant,
http://www.ubersaloons.co.nz/uber3/5lug.htm
use this link
use this link
