wobberly shifter
crawley_boy21
Mon Jun 04, 2007 3:13 am
can anybody shed some light as to why my gear stick can move almost a full circle within the housing and is there a easy method to fix this problem? just that its bloody annoying when you go for third and hit first.
3TWO3i
Mon Jun 04, 2007 4:31 am
Worn gearstick bushings. Happens to all e30's. To fix the problem just get a short shift kit, you'll be laughing. :teehee:
charlE30
Mon Jun 04, 2007 6:21 pm
have a look at http://www.e30zone.net/modules.php?name ... echnz3.htm it lists all the parts you need to replace to get a nice "non wobbly" shift again, short shifter is an extra option while your at it winkeye
Charlie
BMW F31 335d xdrive
ric325i
Mon Jun 04, 2007 6:36 pm
dude only way is the short shift! replace the bushes etc
big choice is the 1.9 short shift or the 2.8/3.0 (i cant remember :roll: ) from the z3?
i had the 1.9 and lost it now so i may go for the 2.8/3.0?
1.9 is the great not too short or heavy.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Mon Jun 04, 2007 7:28 pm
I had a 2.8 - it's kind of cool but it actually slows you DOWN if anything and isn't that pleasent to use day to day.. If I were to go again it would be 1.9 for sure.
zimmerbimmer1
BMW Parts Meister
Mon Jun 04, 2007 7:49 pm
will cost approx £25 for all parts.
best to go for 1.9 as it sits better
pm me your details will get a price for you
frankiez
Mon Jun 04, 2007 9:25 pm
Short shift kit does not make gear changes any quicker. Transmission determines the speed of the gear change. It can feel quicker though. However, it gives better feeling in changes so thats a good reasonf for do it. Do not make too short or it will heavy to change.
Chris
Mon Jun 04, 2007 9:59 pm
Does the Z3 shifter (1.9) sit any lower in the center console or is it just the length past the ball joint that changes?
And does anyone have a link to a guide on replacing those bushes that are worn, making the shifter sloppy?
