Instrument Cluster question
maxel
Thu May 24, 2007 6:26 pm
Hi, I have a 1990 E30 316i and my instrument cluster has no tacho :x and I saw this 4 door E30 sedan part car (same type) and was wondering if I could use the instrument cluster from it (which has a tacho). So simply the question is can I install the tacho into my non-tacho car :? (I'm no mechanic :P :P )
michael24m
Thu May 24, 2007 10:10 pm
replace the whole cluster with the tacho one. it's just plug and play (after you carefully unscrew it from the dash)
Thu May 24, 2007 11:02 pm
There weren't E30s around as late as 1990 with no tacho, were there?
Demlotcrew
Thu May 24, 2007 11:07 pm
Think he might be from over the pont way.
Andrew
maxel
Thu May 24, 2007 11:28 pm
Brianmoooore wrote:There weren't E30s around as late as 1990 with no tacho, were there?
well it is registered but i found out it was produce 12/1989, just dont understand what people are going to do with a clock instead of a tacho
maxel
Thu May 24, 2007 11:29 pm
michael24m wrote:replace the whole cluster with the tacho one. it's just plug and play (after you carefully unscrew it from the dash)
yay u made my day :D
