Jeff_200 wrote:jamesc wrote:Ah I see. Sorry not sure of the answer but i thought the compression only happened when the valves are closed so it should be the same with or without manifolds. I wait to be corrected by someone more knowledgeable.....
The compression value is the max pressure within the combustion chamber (i.e. both/all valves closed), so not having the mani on shouldn't affect it
EDIT: Ideally the engine should be warm when you test it (as any tiny gaps expand with the heat) but it can then be a bastage getting the plugs out
The values you've recorded sound ok to me but if you think you have a compression issue then a leak down test may reveal more.
Cheers.. then il take it mani doesnt effect readings here then..
On my experience so far and the fact that i doubt very much it can read 190psi then 100ish 3 miles later tells me and as already stated i got bad overfueling going on..
That is most defo the case as described above i was idleing for 3-4 seconds a time then switching off to test an oil feed i had..i must of done this a dozen times without letting the engine burn waht was in the chambers..i didnt care about that...my goal was my test at hand.. all the time this was happening i got no AFM connected/3.5 injectors and a Vortex Fuel reg throwing fuel in... So this is the cause of the soiled plugs i hope..
Problem i have now is that when the maifold is back on and i give the engine a good run to burn this shit off i wont be able to access 4 of the plugs to check em again...
Never ever do a TD manifold conversion to save money on a turbo setup..not worth the time,hassle or money saved
