4 lug to 5?
box325
Mon Mar 06, 2006 2:15 pm
How to change from 4 to 5 lug?
I would like to know the different ways of doing this please.
and which ways are the most cost effective, safest, worst etc..
thanks
Kos
Mon Mar 06, 2006 2:20 pm
full e30 m3 suspensionl, or you could go the e36 compact way.
www.pukardesigns.com
IG Pukar.Designs
stevetigger
Mon Mar 06, 2006 2:27 pm
e36 compact cheaper
Doels
Wed Mar 08, 2006 7:57 am
Problem with both KOS and Stevetiggers suggestions is that we here in South Africa never had any of the models (E30 M3 E36 Compact) mentioned. Damn I can do nasty things to BMW SA' s managment for not bringing the E30 M3 to our shores :x
So there are a few other suggestions. Here goes.
1. 325Box, you need to source a 325IS suspension.
2. Redrill the hubs
3. Adaptor plates
I am also interested in this mod
Motorhole
Wed Mar 08, 2006 12:32 pm
Could you not use a Z3 rather than an E36 compact??
Dan318-is
Wed Mar 08, 2006 12:33 pm
Motorhole wrote:Could you not use a Z3 rather than an E36 compact??
Z3 and Z4 suspension will both work i believe!
scotty86d
Thu Mar 09, 2006 12:19 pm
Cam you literally just offer up the z3/4 or compact suspension and it will mount ok on the steering rack, wishbones and the arb links up front. And what about the rear. Is there a combination of bits you need?
Motorhole
Thu Mar 09, 2006 12:38 pm
Surely Z4 suspension would offer a considerable handling improvement also...after all it is supposed to be a massive improvement on the Z3!?
scotty86d
Thu Mar 09, 2006 5:19 pm
yes but it would cost a fortune. Not everyone has Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£s to lavish on their cars
surely e36 compact or z3 would be a more viable option pricewise
Thu Mar 09, 2006 7:10 pm
Z3 M on the left, standard E30 on the right
Much larger hub, but almost identical apart from the gusset
Dont know if the standard Z3 is the same though
bottlecapE30
Fri Mar 10, 2006 12:16 am
i wonder if this would correct + camber from lowering because in the photo it looks like the hub is at a different angle :idea:
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
buster
Fri Mar 10, 2006 12:16 pm
does the abs still work using e36 stuff ??
Fri Mar 10, 2006 12:23 pm
Cant see why not, have to use the E36 sensors though
Aico
Fri Mar 10, 2006 3:29 pm
To much caster if you're going to swap to E36 suspension at the front.
buster
Fri Mar 10, 2006 3:50 pm
Aico wrote:To much caster if you're going to swap to E36 suspension at the front.
Not if you use eccentric bushes
Aico
Fri Mar 10, 2006 3:59 pm
Even then there is way to much castor. Bushings or even a fully adjustable uniball at the rear of the controlarm won't do the trick.
buster
Fri Mar 10, 2006 4:02 pm
glenns m5 powered e30 seemed ok,and there are other people using e36 front legs so i dont think its a problem.
Aico
Fri Mar 10, 2006 4:21 pm
It does fit, no problem there. You can just drive the car, no problem either. You just will lose front end grip because of the castor. If it's a street machine then you might not even notice it. The E30 already understeers from the factory and now you make it understeer even more. There are people who are racing with this kind of set-up, but it doesn't mean it drives really well. It can be corrected with massive neg camber, but that's only usefull for racingcars.
kam-325i
Fri Mar 10, 2006 4:26 pm
Aico wrote: The E30 already understeers from the factory and now you make it understeer even more.
Never noticed that before.....
Motorhole
Fri Mar 10, 2006 4:48 pm
It does, trust me! When taken on a track and driven smoothly and precisely for fast laps, it tends towards understeer. Oversteer arrives with heavy-footedness and raggy steering (And naturally unpredicable road surfaces when not on the track!). A slight tendancy towards understeer when driven properly is the sign of a very well set up car you know!
Fri Mar 10, 2006 6:06 pm
Well what about the Z3 front arms?
Or Z4 arnt they near enough the same
Aico
Fri Mar 10, 2006 10:38 pm
The E30 and E36 control arms are the same. The problem is not the control arm, but the design of the E36 hub.
Fri Mar 10, 2006 10:49 pm
So apart from E30 M3, what would be the ideal cost effective alternative
