rear shocks tourer/saloon
MATTTT
Tue Jan 17, 2006 9:51 pm
has anyone ever fitted the saloon rear shocks to a tourer?
just ive been offered a set but i saw they are listed as differnet for the estate to the saloon
thanks
matt
massive
Tue Jan 17, 2006 10:11 pm
The car will sit lower due to the weight difference. They should fit
Simon
Tue Jan 17, 2006 10:22 pm
I have saloon rear shocks on my touring, but they are uprated shocks, I wouldn't advise fitting 2nd hand 316i shocks to a touring etc.
It's the springs that govern the height on a car, not the shocks BTW 8)
MATTTT
Tue Jan 17, 2006 10:30 pm
so if they turn out to be off a saloon the ones off a 325 and 320 would be similar to the standard 318 tourer rating?
i know new ones arnt a lot though
i thought the springs gave the ride height too nothing to do with shocks?
Simon
Tue Jan 17, 2006 10:46 pm
No that's right, the dampers are there to 'dampen' the bumps, the springs keep the car at a certain height, and take the majority of the work from the dampers.
If you're buying 2nd hand stuff, I'd say yes go ahead if they are uprated items i.e. bilsteins/H&R's etc, but I wouldn't put standard shocks from a saloon on a touring.
toby
Aren't the touring shocks stronger - originally designed to cope with extra loadings such as dogs and guns in the back for hunting in the German countryside?
Simon
Tue Jan 17, 2006 10:48 pm
toby wrote:Aren't the touring shocks stronger - originally designed to cope with extra loadings such as dogs and guns in the back for hunting in the German countryside?
Yes, that's why I said if they are uprated items they will be fine, my touring handles great on saloon bilstein shock absorbers.
MATTTT
Wed Jan 18, 2006 3:39 pm
well spoke to the guy and they are def off a saloon
but he did say they are gas ones off a 325i so i might put them on and try them,i assume the oil filled ones were standard and aftermarket are gas ones?
