Removing the crank bolt from a stripped engine
George_Of_The_Jungle
Tue Aug 27, 2013 7:58 pm
Engine is stripped down, out of the car, everything removed apart from the crank.
How can I undo the 320LB torqued bolt from the front of the crank?
I have wedged a crow bar inbetween two of the crank counter weights, and tried using a pretty long breaker bar on the bolt in the end, but this results in the engine stand bending.
Any advice would be most appreciated.
George
Tue Aug 27, 2013 8:04 pm
I have found a video which makes it look easy with two people..... Alas I have no one else to hold the engine stand down (and my rattle gun only makes a lot of noise and does not undo the bolt)
**BANNED**
Tue Aug 27, 2013 8:09 pm
This is possibly the most diffcult bolt to loosen on an E30!
The only way I have managed it was with the engine still in the car,long bar on a lump of 4x2 and flick the ign key...
Not much use to you now.
Do you have a mate with a fork truck,at work,perhaps?
Mount the block on a pallet,thick plywood over the top held down with the f/l whilst you heave on the bolt?
A mate with a compressor may be able to shock the bugger free?
Youth is wasted on the young.
jimbom30cab
Tech 1 freak
Tue Aug 27, 2013 8:26 pm
I did mine at the weekend and found it easier to do it with the engine on the deck and a large mate standing on it then get the right angle on the breaker bar so if pushes the engine into the ground. Still had to jump on the breaker bar.
Engine stand will just bend or move in my experience
Good luck
HairyScreech
Tue Aug 27, 2013 9:15 pm
Get a block of wood and wedge it between the block and the no1 rod journal, get a long bar and stick you foot against the block.
reggid
Tue Aug 27, 2013 10:13 pm
prop up one side of the block with a piece of wood so the force you put on the breaker bar that tries to rotate the block in the stand and bend the actual stand goes into the ground
E30 325is with M20B31
