Hi guys
I'm in the process of selling my iS and I've been asked if it has an LSD.
Did the iS come with the LSD as standard or was it optional?
Ta Muchly
Does the 318iS have an LSD?
richardlkay
Rick
_______________________________________
E30 (91) 318iS - Alpine White II|14" BBS Cross Spokes|Cloth Sports seats
B7 (07) Audi A4 2.0 TD
mrLEE30
I think it was optional. Look at the diff from the rear and you will see a metal tag about an inch long on one of the bolts. An S at the start of the code - probably S4.10 XXXX- idicates it is an LSD
Optional, not many have them.
Can you see on the right hand rear side of the diff, there is a little metal tag. If you can read what is on that is should tell you the ratio of the diff, probably 4.1:1, if is has an "S" at the beginning of the number then it should be a LSD
Sorry I started typing that reply and then got called away from the computer
cecotto479
- Caution Unreliable Seller
- Contact:
These methods only work if the tag exists or is legible. Alternatively, safely jack up the rear with both wheels off the ground, out of gear and handbrake off. Manually spin one rear wheel. With an LSD, both wheels will spin in the same direction, with an open diff they'll counter rotate.
1981 E23 735i
- bullwinkle
Can i have a few details please or a linky to the ad - poss looking for another one to add to the stable!
