Sump removal
sweep
Wed Jun 16, 2010 9:18 pm
Is it possible to remove a 325i sump with the engine in place im 99% sure you can but the car is in the garage so i cant go out and have a look.
murran
Wed Jun 16, 2010 9:51 pm
best way is to undo the engine mounts. get your engine crane out or use your support beam thing to lift/hold the engine up as far as it will lift up off the mounts. best way of getting the room needed.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
hazd31
Wed Jun 16, 2010 9:57 pm
it can be, i found it easyest to remove the steering rack to give extra clearance, and get the car as high as possible!
murran
Wed Jun 16, 2010 10:03 pm
drain the oil out first!
yeah_mick
Thu Jun 17, 2010 2:15 pm
i done this last week for the 2nd time, 1st time i had an engine crane which was far easier, just undone the engine mounts and lifted the engine as high as possible. or if you dont have a crane, you want to jack the car up then you will need to suppourt your engine, i used a pile of bricks under the sump, i tinhk undone the mounts, removed the 4 bolts for the subframe, and the 2 bolts on either front arm where they bolt by the chassis rail, i then pulled the subframe down and pushed it towards the back off the car. i could then get supourts under the engine mounts to hold the engine whilst i removed the bricks from under the sump and removed the sump.
thats the only way to do it i can see with out a crane, its a pain in the arse and i wanted to cry but its not that bad of a job just takes so long,
