larger brakes
renoops67
Thu Sep 03, 2009 12:02 am
Hi i have a 320i that i have used for track days and a couple of races, at the moment i have striped it down and i am puting a 2.5 engine in, i would like to put larger brakes on but not sure what would fit, does a e36 have larger brakes and would they fit on ok ? any advice would be great many thanks
chriskkk
Thu Sep 03, 2009 12:16 am
i used g60 discs and rx7 calipers on front and e46 320d disks and calipers on rear all on ds3000 pads, works quite well on 15 inch wheels with spacers
renoops67
Thu Sep 03, 2009 12:35 am
Do the g60 disks and rx7 callipers fit straight on or do i have to modifi them? and is the g60 disk a 4 stud
hongkongfuey
Mad-tango-geezer
Thu Sep 03, 2009 5:37 pm
would be intrested to know this too, also what size discs are they???
with cars like mine,
DHFiS
Thu Sep 03, 2009 7:28 pm
I have got the calipers and the discs for the front but not had time to fit them yet. Didnt know about the e46 rears.
What m/c are you using chriskkk?
info here
http://www.e30zone.net/modules.php?name ... ke+upgrade
renoops67
Thu Sep 03, 2009 8:17 pm
hongkongfuey wrote:would be intrested to know this too, also what size discs are they???
looking in the book bmw discs are 260 x 22mm the g60 discs
are 280 x 22mm, just not quite sure if they go straight on
BadDave
Thu Sep 03, 2009 8:35 pm
the G60 disks are 280x22 and should be 4 stud.
The centre bore needs increasing by 1mm and you also require a 2mm spacer between the hub and the disk
The RX7 caliper isn't a straight bolt on job,it does require a caliper bracket made up, but it's pretty straighforward to make one.
The E46 disks mentioned will be 5 stud, so will need re drilled to match the E30 rear hub(4x100mm).
IIRC you can use a std BMW handbrake setup with those.
There are a few different options listed over on www.300mm.de
HTH
chriskkk
Thu Sep 03, 2009 10:09 pm
The G60 disks are 4 stud but as mentioned you need a lathe to take off a very small amount to increase the hole in the middle. I did not need a spacer between hub and disk but machined a bracket using a drawing off the internet, bascially you offset the caliper. Its very very easy for the front brakes, the rears however had me swearing a bit.
The rear disks on a e46 320D are vented which is why i chose them, they also keep the handbrake intact , re-drilling with a hand drill needs huge patience to make sure the holes are correct, i used a dial guage to keep checking for eccentricity. The calipers i used were also 320D but they are heavy and i would have preferred to use some alloy ones but was in a hurry. The calipers do not just bolt on you will need to fabricate a bracket and weld it onto the rear arm.
Using larger 730i MC
Hope this helps
renoops67
Thu Sep 03, 2009 11:09 pm
Thats great thanks for your help, will get on to this in the next
couple of weeks.
Thu Sep 03, 2009 11:15 pm
I have the WMS 4 pot kit which uses G60 disks, they work very well 8)
keri-WMS
Fri Sep 04, 2009 1:32 am
If it helps anyone I've got the 280mm G60 discs pre-machined to fit E30 on the shelf - drop me a PM if you need some! :cool:
DanThe wrote:I have the WMS 4 pot kit which uses G60 disks, they work very well 8)
Ah shucks! :D
e301988325i
Fri Sep 04, 2009 4:47 pm
Keri, do you have any of the 2mm spacer plates for the g60 discs in stock?? How much inc delivery to please :D
I said:
e30topless said:
lock the wife in there
keri-WMS
Fri Sep 04, 2009 5:26 pm
e301988325i wrote:Keri, do you have any of the 2mm spacer plates for the g60 discs in stock?? How much inc delivery to please :D
Yup, 2pr of them! :D
£19.20+vat/pr + £2.00+vat p/p = £21.20+vat (£24.38 all in)
Hope that helps!
renoops67
Fri Sep 04, 2009 7:45 pm
Do you know who supplies the wms kits?
dips346
London Meets Main Man
Fri Sep 04, 2009 7:50 pm
renoops67 wrote:Do you know who supplies the wms kits?
the guy above ?
renoops67
Fri Sep 04, 2009 8:34 pm
Thank missed that above its been a long day :eek:
hongkongfuey
Mad-tango-geezer
Fri Sep 04, 2009 10:12 pm
are 5mm spacers too big ??? I have a pair of them if anyone wants them???
