Basically I'm pretty sure my pistons are right, but they stick up above the top of the deck and I'm pretty sure they shouldn't!
I'm using an M52B28 crank and 135mm rods, and when I measured the pistons, the gudgeon pin was 4.5mm closer to the top of the piston than standard which would allow for the 9mm increase in stroke.....which all leads me to think that maybe the block is too short
'Elp!
Cheers!
