where is it??
rishi
Sat Apr 04, 2009 10:58 pm
where is the relay for the indicators? 318is e30 cab k reg. was wondering because the indicator flashes fast when i turn right but all the bulbs work. when i turn left it is fine
Dave_M3
Sun Apr 05, 2009 3:35 am
attached to the underside of the steering wheel column.
Take off the steering wheel,
then take off the trim and shroud under the column.
You'll see the black relay underneath then not far from the indicator stalk itself :wink:
blingsta
Boost Junkie
Sun Apr 05, 2009 3:52 am
are both the bulbs flashing fast or just one? have you tried changing the bulbs around?
Sun Apr 05, 2009 10:34 am
The indicator 'relay' doesn't know which way you are indicating, so if it works properly for one direction and not the other, the fault is not there!
Either a bulb is out, or there is a resistance somewhere in RH indicator wiring. Put the hazards on, and compare brightness of the bulbs.
The problem is most likely with the front indicator, but could also be the rear light cluster lamp holder assembly (including the relevant pin on its socket), the hazard switch, or the column indicator switch.
hennabm
Sun Apr 05, 2009 3:05 pm
I've had problems with my ns indicator when I've changed bulbs etc in the rear panel. If I don't get it quite right, the ns indicator doesn't work until i twist the securing lock again on the bulb holder panel.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Sun Apr 05, 2009 3:56 pm
hennabm wrote:I've had problems with my ns indicator when I've changed bulbs etc in the rear panel. If I don't get it quite right, the ns indicator doesn't work until i twist the securing lock again on the bulb holder panel.
You need to tighten up the buckets a bit on the rear lamp sockets.
rishi
Mon Apr 06, 2009 10:19 pm
changed the bulbs but still the same problem.. :(
Dave_M3
Tue Apr 07, 2009 12:22 am
Is the actual bulb holder ok though?
As Brian mentioned eariler... Very common problem at the front in my experience
rishi
Tue Apr 07, 2009 11:23 am
have an e36 front bumper and its using side repeters as front indicators, :-S dont ask why. looks shite
