springs
trex
Post Wed Apr 01, 2009 8:59 pm
my car has a set of lowering springs
how do i get them out
thanks the rear ones just
al
Mox3d
Post Thu Apr 02, 2009 12:08 am
Lift the car on a ramp or onto axle stands. Remove rear wheels. Undo the lower damper bolts to release both swing arms and to let those hang lower. Ease the springs out.
leeparkes
Post Thu Apr 02, 2009 12:33 am
Mox3d wrote:Lift the car on a ramp or onto axle stands. Remove rear wheels. Undo the lower damper bolts to release both swing arms and to let those hang lower. Ease the springs out.
put a jack under the trailing arm when you undo the damper bolt,also you may need to force the trailing arm down before the spring will come out.
georgen
Post Thu Apr 02, 2009 12:36 am
I'm sure I had the handbrake off when I changed the rear springs on the touring too...
01' 330ci Sport
02' 530i Sport Saloon
52' 330i Individual Touring
leeparkes
Post Thu Apr 02, 2009 12:39 am
I had to force the trailing arms down with a scaff bar to get the springs in and out
georgen
Post Thu Apr 02, 2009 12:46 am
leeparkes wrote:I had to force the trailing arms down with a scaff bar to get the springs in and out
For fitting the buggers I did the following: Stuck the springs in a vice, tied them with some VERY strong cable ties, slotted them into place, then cut the cable ties off. Worked just fine :D
01' 330ci Sport
grantfk10
Post Thu Apr 02, 2009 12:50 am
georgen wrote: For fitting the buggers I did the following: Stuck the springs in a vice, tied them with some VERY strong cable ties, slotted them into place, then cut the cable ties off. Worked just fine :D
Sounds like a good idea!
georgen
Post Thu Apr 02, 2009 12:59 am
It did work well Grant, but the ties have to be of the chunkiest variety ( supplied free from work winkeye ). Wee ones will just break and no doubt cause a painful hand injury..
01' 330ci Sport
leeparkes
Post Thu Apr 02, 2009 1:00 am
This did cross my mind but i had visions of the cable ties snapping,
years ago i nearly had a spring compressor fetch my ear off when it sliped off the spring,it landed on my neighbours drive (3 houses away)
grantfk10
Post Thu Apr 02, 2009 1:04 am
georgen wrote:
It does work well Grant, but the ties have to be of the chunkiest variety ..
I think I have some of those in my garage .....also supplied from previous workplace winkeye
Mox3d
Post Thu Apr 02, 2009 8:17 am
just follow post 2 :roll:
trex
Post Thu Apr 02, 2009 9:02 am
thanks for all the help ill give it a go today
cheers
al
georgen
Post Thu Apr 02, 2009 10:32 am
Mox3d wrote:just follow post 2 :roll:
Why the roll ? Is this not a forum where ideas are swapped and pondered over, and then perchance attempted ?
Granted, some ways will work better than others. All I was doing was sharing my experience of the job and passsing on my thoughts and suggestions.
You've really got my back up with that post !!
01' 330ci Sport
Mox3d
Post Thu Apr 02, 2009 7:53 pm
Because you're going to seriously hurt yourself or someone else some time with that god awful advice. I got your back up ? lol@u
Put a spring into a vice??? Use tie wraps????
georgen
Post Thu Apr 02, 2009 9:15 pm
Mox3d wrote:Because you're going to seriously hurt yourself or someone else some time with that god awful advice. I got your back up ? lol@u
And that's all it is, advice. People can use it or not. The technique worked for me, it may not work for others but I believe that that's up to the individual to decide / try.
And what makes you think that 10 huge cable ties slightly compressing a rear spring will all break, leading to a horrendous injury ?
01' 330ci Sport
Mox3d
Post Thu Apr 02, 2009 9:42 pm
Enough. You're on you're own.
edit: specifically to georgen (not trex) who recommends you put yourself at serious risk by compressing a spring in a vice, to put tie wraps around it. And calls that advice.
That, people, is an accident waiting to happen. Wake up!!!!
georgen
Post Thu Apr 02, 2009 10:06 pm
Mox3d wrote:Enough. You're on you're own.
I've already carried the job out successfully on my own, as previously stated..
01' 330ci Sport
BadDave
Post Thu Apr 02, 2009 10:15 pm
It also helps if you use spring compressor's to compress the spring before trying to wriggle it out
It's also easier to fit the replacements if you use the spring compressor's as well.
Mox3d
Post Fri Apr 03, 2009 9:19 am
Lowering springs would not need to be compressed at all. Standard springs need to be eased out a little bit. There is no call to compress any spring in any part of of this simple operation.
That is all.
georgen
Post Fri Apr 03, 2009 10:01 am
Mox3d,
You're starting to repeat yourself. Re-read the posts again please. Mine have never carried the recommendation that others carry out this procedure. I, as already stated, have mearly explained the way that I did it.
I am not prepared to fall out with any zoner over a matter like this, so I'm asking if we can agree to disagree ?
01' 330ci Sport
Post Fri Apr 03, 2009 10:36 am
Settle down, ladies!
I would expect a lowering spring to go in and come out with no compression at all. Standards springs will just about go in and out, but some force is needed, and compressing the spring slightly is desirable.
I have to agree that georgen's method is a little on the dangerous side - the energy, even in a lightly compressed spring, is quite impressive, as is the damage it can do and distance it can travel if it comes loose.
My spring compressors are of the hook on type, and I still get extremely nervous when using them!
I also tie the spring to a solid object with a short length of thin rope to keep it under control if the clamps slip.
Kemlo
Post Sat Apr 04, 2009 10:05 pm
I have used a load strap in addition to spring compressors too, heavy duty one though. Gave me just a little bit of extra confidence.
I struggled with getting my lowered springs out today - no issues getting them in mind.
jbh
Hartge Crew
Post Sat Apr 04, 2009 10:10 pm
did a few sets of rear and front springs in my time i normally use spring compressors and have had one slip on me once I've never had a set come off so i suppose I'm lucky there. I've seen ppl using far worse things to compress spring than cable ties
Dave_M3
Post Sun Apr 05, 2009 1:59 am
It helps if you disconnect the arbs too as it makes moving the trailing arms up and down that little bit easier.
I found my Eibachs needed a slight bit of compression to put in... the cheap lowering springs I took off practically fell out once I disconnected the shocks, lol.
