idle problems in morning
rikster
Tue Mar 24, 2009 3:01 pm
the last two days in the morning the m20 2.5 has been a bit rough it idles a bit high and drops when you press the throttle and sort of splutters till you get to 2000 rpm and its better, only lasts about 5 mins worth of driving and its fine could it be the idle control valve any help cheers
moh110
Tue Mar 24, 2009 3:23 pm
i had this problem with mine, although it was an m40. i assumed it was just an old car, taking a while to warm up, but if it has just started to happen on yours id be interested to find out what the cause is.
rikster
Tue Mar 24, 2009 4:29 pm
yeah it has just started its not done it before
blingsta
Boost Junkie
Tue Mar 24, 2009 6:15 pm
blue temp switch mate ! it tells the ecu the engine is cold and givves the correct amount of fuel :D
rikster
Tue Mar 24, 2009 6:56 pm
where would i find this is there another name for it cheers
blingsta
Boost Junkie
Tue Mar 24, 2009 11:35 pm
you have got 2 plungs/switches on the thermostat housing mate... follow you rads top house.. on switch is brown, the other is blue... they are screwed into the thermostat housing with a 19mm spanner.. make sure the engine is cold when you unscrew it. :D
moh110
Wed Mar 25, 2009 10:28 am
could this also be the reason for the engine running rich?
blingsta
Boost Junkie
Wed Mar 25, 2009 10:29 am
yep !...
LeonNewton
Wed Mar 25, 2009 10:49 am
Think i may need one of thies. do we know the part nomber?
Yer i am sorry for my bad spelling. i am dislexic and find it just as hard to read your posts as you do mine.
blingsta
Boost Junkie
Wed Mar 25, 2009 11:02 am
LeonNewton
Wed Mar 25, 2009 11:19 am
thank you. seen this site so many times and naw i have finaly bookmarked it.
blingsta
Boost Junkie
Wed Mar 25, 2009 11:20 am
good man... can come in handy
Aubs
Aka Mr_Gerbic_iS
Wed Mar 25, 2009 11:57 am
I am also occasionally rough and idle in the morning :)
rikster
Fri Mar 27, 2009 9:55 am
blingsta you was spot on mate i disconnected the blue plug while it was running and it settled down smooth off to bmw now cheers mate :D
blingsta
Boost Junkie
Fri Mar 27, 2009 10:13 am
:banana:
easy
Sat Mar 28, 2009 2:51 pm
where is that on the m40 316 engine? Mine has exactly the same symptoms, rough idle for 5-10 mins and running rich.
