welding
trex
Post Tue Jan 06, 2009 5:34 pm
my driver side rear arch has a golf ball size hole in it
and there was like an arm that came from the rear axle up
to were the hole is what is this arm is it ok to just weld back to
the arch thanks for the help
AL
Daf318is
Post Wed Jan 07, 2009 8:43 am
Is this "arm" the damper? I assume this hole is inside the car not outside? A picture would help :)
Daf
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
trex
Post Wed Jan 07, 2009 9:28 am
yes from the inside but when you take off the wheel i can cee in yhrew the arch
Daf318is
Post Wed Jan 07, 2009 9:56 am
Patch should be fine for this, just make sure it is seam welded otherwise it will fail MOT. I'm guessing it is the damper you are talking about with the "arm" - take this off before welding - it contains pressurised stuff - I have never heard of one being damaged by welding in the vicinity but for the sake of 2 bolts and 5 mins to remove it - I would!
Also take care with fuel tanks and lines as they run relatively close to this reigion - again a pic would help :)
Daf
trex
Post Wed Jan 07, 2009 10:15 am
ok nice ill try get some pics
sihooker
Post Wed Jan 07, 2009 10:26 am
Dont forget to disconnect the battery AND the ECU mate..best to be on the safe side :wink:
Daf318is
Post Wed Jan 07, 2009 10:30 am
I knew there was something else I forgot :o:
sihooker
Post Wed Jan 07, 2009 10:31 am
:teehee:
trex
Post Wed Jan 07, 2009 11:07 am
will do thanks
