is anyone running a 60mm drop with 9in wide wheels?
scottiemorris
Thu Nov 13, 2008 7:59 pm
ive just lowerd my car 60/60 and havent put my 9in wide borbets back on yet, its spax gas adjustable suspension and is very stiff, will it rub with me and a passenger? i dont expect anyone can go in the back. if anyone has got this could i see a pic to judge how close it will be? thanx guys
leeparkes
Thu Nov 13, 2008 9:49 pm
whats the offset of the wheels?
will be stamped ET then a number
Jonsku
Fri Nov 14, 2008 8:02 am
I guess the ET is 15, it will rub if you haven't rolled your arches.
I've 10" wide rim, ET14, with 245/35 rubber and it doesn't ever rub. Car is lowered ~80mm at the back, though the arches have been rolled a lot :)
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E30_Aza
Fri Nov 14, 2008 5:58 pm
im running 60mm with 9j borbets and yes the rear rubs. get them arches rolled!!!!
scottiemorris
Fri Nov 14, 2008 9:42 pm
cheers guys, another question, rolled arches-the small lip inside the arch about a thats about 1.5cm is just bent up so the arch has no lip, you know what i mean? and what is flaring the arches?
