weird rubbing noise
sohood
Post Mon Sep 15, 2008 12:37 am
my cab is making a weird noise which sounds like tyre tread touching the body somewhere- a rotational noise, and it happens only when moving/acceleration and turning the steering slightly to the left...
it never happens when the steering is turned more or from standstill, only on the move... i have had the car mot'd recent, replaced the wishbones, ball joints and drop links and have inspected for any tyre rubbing but have had no luck :S
what else can it be??
Post Mon Sep 15, 2008 9:24 am
Check the backplates on the disc brakes.
jakkerd
Post Sun Sep 21, 2008 9:55 am
I have the exact same problem. How do i check the backplates (what are those anyway, i'm not english so i don't understand all the terms)?
jakkerd
Post Fri Sep 26, 2008 6:19 pm
Took the front wheels of today, didn't find anything wrong with brakes at all.
However, when i sat the car down on it's wheels again, I heard al little 'ka-tink' coming from the brakes. Kinda like something snapping in to place or, perhaps, out of place.
I don't have that much experience with cars, especially e30's. So any guidance is appreciated :).
pnd
Post Sat Sep 27, 2008 9:32 am
sticking caliper? feel the wheels after a long run is one hotter than the other if it is you may well have a sticking calliper common on e30's
sohood
Post Fri Dec 26, 2008 12:41 am
it turned out it was the wheel bearing on mine
