316i Overheating again!
Aido
Sun Aug 31, 2008 10:53 pm
Hi guys and girls,
my 316i is overheating while driving on the open road and in traffic,it just goes over the half way mark on the temp gauge but im afraid to drive it on long journeys just incase i do damage what do i need to get to stop this from happening?viscous coupling maybe??
Sun Aug 31, 2008 10:57 pm
its suppose to be on the halfway mark, if its just over it could possbe the rad on its way out or thermostat
Sun Aug 31, 2008 11:00 pm
If it goes just over the half way mark it's NOT overheating! It's overheating when it approaches the red sector.
Check the small brass nuts on the back of the instrument cluster are tight.
peterjcollins
Sun Sep 14, 2008 7:52 pm
Hi,
Providing the temp gauge doesnt keep rising while driving along and it stays just past the middle it is ok. If you stop and crawl in slow moving traffic and the temp begins to rise then suspect definately the viscous fan unit £30 at Euro car parts.I had similar with my 318i in slow moving traffic and the only way to lower the temp was to open the windows and put the heater on full blast,this will help to lower the engine temperature. My problem was the viscous and since i have changed it all is ok.
Good luck
Pete
StefanAnghel
Sun Sep 14, 2008 10:33 pm
keep us update fella cause I might have the same problem
scottidog
Sun Sep 14, 2008 10:38 pm
If its not the spring on the thermostat starting to relax its the viscous fan coupler thats aged... nothing to worry about for the moment mate, you wont damage the engine unless its very close to.. or in the red.
Sun Sep 14, 2008 10:40 pm
stefananghel wrote:keep us update fella cause I might have the same problem
OP doesn't have a problem!!
StefanAnghel
Tue Sep 16, 2008 3:25 am
OP? :o:
Aido
Thu Sep 18, 2008 3:33 pm
well she seems ok again, needle seems to stay below the halfway mark so im happy with that
