advise on rocker cover gasket seal
hi just need some advise on doing a rocker cover gasket seal on my 318 cab, does any one know the torque settings for the bolts when putting the rocker cover back on? many thanks shai
Oki-koki
Just looked it up and it says that it depends on what size of bolt/nut is used...
M6 thread (10mm head) is 10 N:m
M7 and 8 (7=dunno probably 12mm 8=13mm head) 15 N:m
On your M40 engine it will probably be the M6, and a torque wrench for that kind of torque won't be cheap so i would just nip them + a little.
1 N:m is about 100 grams of pressure on a 1 meter bar = 1Kg on a 10cm bar like a 1/4" ratchet, pick up a 1Kg tub of butter or 1 litre bottle of water to get an idea of what that feels like
I hope that's of some use
- siddiqi1
- BFG Zone Contributor
Shai,
you may find it easier to put it under your posts; such as simon the mod has done and I; than to put it on the left of the screen; as it pushes all the page over!
do you know how to do that?
