orr
Tue Jun 10, 2008 6:36 pm
Hello ,can anyone help i have an s50 engine in my e30 m3,when i am driving it and floor it in say 3rd gear when i am going slow the engine sounds like it is pinging alot ,does my head in ,is there any reason for this ,thanks
Ant
- Retired Team Member
Tue Jun 10, 2008 6:41 pm
they are quite metallic sounding, has the exhaust manifold been modded at all ?? it could have cracked @ a welded joint
I assume you're using super dooper unleaded(98+ RON) ???? if not then thats the issue
If in doubt, get a full diagnostic done, inc a live data check to see if its indeed knock.
Either way, check it all out BEFORE abusing the loud pedal too much- just in case.....
to clarify, S50B30 or B32 Evo mill ?
Email FTW
orr
Tue Jun 10, 2008 7:26 pm
thanks ant it a s50 b30,and yes i made the manifold but no cracks in it,i only had to change one pipe.also i am just using normal petrol from sainsburys
stonesie
Tue Jun 10, 2008 7:35 pm
Try it on 98 ron, costs a bit more but less than a melted piston
orr
Tue Jun 10, 2008 8:26 pm
i will try some 98 ron in it, i just thought the knock censors would stop it from pinging,how much are your charger kits for the s50 Ant
old_skool
Tue Jun 10, 2008 8:52 pm
I've experienced pinking on all the S50B30 & 32 cars that I have owned. Even my S54 engined M3 did it occasionally. I asked at my dealer desk a few times and they said simply that they can be prone to it and was I using cheap low RON fuel. I've had this discussion with other S50'd owners and they have mixed reports about pinking from time to time.
I found that funky petrol made no difference to any of my cars but I've never been truly scientific about it. I'm sure that it probably does make a slight performance increase when measured accurately but it never seemed to help with the pinking at all.
old_skool
Tue Jun 10, 2008 8:54 pm
Just to add, it's always happened with me below 3000rpm when under load in a low gear. Especially when at moderate throttle using the low torque band.
orr
Tue Jun 10, 2008 9:17 pm
that just sounds like mine under 3000rpm, if you nail it from a standstill its fine,also if you set of in 2nd it does it alot,must be something wrong,i dont think they would sell them like this new
bilun777
Wed Jun 11, 2008 8:34 am
Look for a big Tesco's.Mine sells 99 octane fuel.
If it aint broke don't fix it!
Ant
Wed Jun 11, 2008 11:23 pm
pull the spark plugs out too, see whats fitted
Email FTW
orr
Thu Jun 12, 2008 5:22 pm
what are the best spark plugs to put in it ,how much are your charger kits Ant for my engine ,what power are you looking at thanks.
old_skool
Thu Jun 12, 2008 5:36 pm
Bosch Y5 DDC are what the dealers recommend. I have had them in both 3.0ltrs and they are fine.
Ant may recommend different plugs, moreso if it's going to be supercharged
orr
Ant
Thu Jun 12, 2008 8:42 pm
Drop me an email on the kits dude, direct selling is not permitted on the forum, even for admin members
pull the plugs, see if the wrong ones have been fitted ???- quite common
Email FTW
orr
Fri Jun 13, 2008 8:51 pm
just looked at the plugs and they are NGKR PKR7A are they right or wrong
thanks
ian332isport
Fri Jun 13, 2008 11:26 pm
orr wrote:just looked at the plugs and they are NGKR PKR7A are they right or wrong
thanks
Correct for a 3.2 Evo engine (S50B32), but wrong for a 3.0L.
orr
Fri Jun 13, 2008 11:41 pm
thanks Ian what will it do having them in
are the bosch y5 ddc correct
csl
Sat Jun 14, 2008 12:15 am
I'm still here!..............haven't seen you in a good while mate. Hope your still enjoying that nice M3!
orr
Sat Jun 14, 2008 12:19 am
yes i have had it just over 10 years now,still got your sport,you will have to pop in when your around this way.
csl
Sat Jun 14, 2008 12:29 am
Yeah,still waiting for that ride you promised
.........the Sport is still with me,tucked away in the garage awaiting my days off/nice weather
orr
Sat Jun 14, 2008 12:36 am
nice car that ,give me a pm next time your near and i will come and take you for a spin
csl
old_skool
Sat Jun 14, 2008 11:51 am
I'm running, sorry, was running Y5 DDC plugs in the S50B32 now owned by BSS325i. They are the plugs recommend and sold by the dealer for that engine.
Sat Jun 14, 2008 2:31 pm
old_skool wrote:I'm running, sorry, was running Y5 DDC plugs in the S50B32 now owned by BSS325i. They are the plugs recommend and sold by the dealer for that engine.
B32?
old_skool
Sat Jun 14, 2008 2:34 pm
ooops, sorry Barry, just gave you a free upgrade by mistake
I meant B30 Doh!
Sat Jun 14, 2008 3:58 pm
I must say, i have noticed pinking under load at low rpm's.
orr
Sat Jun 14, 2008 6:04 pm
I will get some new plugs on monday,i filled the tank yesterday with 99 ron and that seems to have done the job
,but i will change the plugs anyway if there wrong thank you all
Ant
Sat Jun 14, 2008 6:08 pm
^ good effort dude !
told ya to check the plugs, 9/10 I see have the wrong ones fitted, NGK are best too
Email FTW
orr
Sat Jun 14, 2008 6:52 pm
nice to talk to you the other day Ant, top man , all you zoners need to move up north :)are the bosch ones no good becouse i have just bid on some on ebay
- Homo Hair
Sun Jun 15, 2008 10:53 am
Gotta love it.. Maintainance of an S50 on a budget..
