service Symptoms
HUSSAIN
Fri Jan 25, 2008 10:45 pm
ok guys what are the symtoms for a service?
il tell you what my cars does and if it is a service then let me know please
1...takes too much fuel even at small drives
2...when the car is warm the car rocks side to side, as if the engine is choking (i hope you understand what i mean) well put it this way after the car is warm it sounds like a subaru impreza with a quite exhaust
3...you can smell fuel through the heaters at times
i was about to change the easy bit such as plugs, leads filters and leave the oil filter and oil change to a mechanic, but i thought il ask before doing the a service
cheers
march109
Fri Jan 25, 2008 10:50 pm
Sounds like its overfuelling or has a slight fuel leak to me.
Not really a sign that it needs a general service more rather a sign theres a fault hich needs addressing.
Fri Jan 25, 2008 10:52 pm
These symptoms are nothing to do with a 'service'. They are just symptoms of faults!
You haven't said what engine, but check the 'blue' water temperature sensor, and the condition of any rubber fuel hoses close to the engine.
HUSSAIN
Fri Jan 25, 2008 10:56 pm
Brianmoooore wrote:These symptoms are nothing to do with a 'service'. They are just symptoms of faults!
sorry my fault...its a e30 325i engine
march109
Fri Jan 25, 2008 10:58 pm
didn't I say that in fewer words?
Fri Jan 25, 2008 11:16 pm
march109 wrote:didn't I say that in fewer words?
Yes, but you hadn't said them when I started my post!
Fri Jan 25, 2008 11:17 pm
HUSSAIN wrote:sorry my fault...its a e30 325i engine
In that case, add the injection loom plug and socket under the inlet manifold to the list.
