how easy is a single wiper conversion?
potman
Tue Jan 15, 2008 7:24 pm
fancied doing a single wiper conversion on my 320, but i'm not sure on how to do it. do i need a special motor, or can i adjust the throw on the motor it has already? any info or advice will be greatfully recived.
thanks.
live, love and drive like today is ur last.
FlappySocks
Tue Jan 15, 2008 7:28 pm
:chainsaw:
agreen
Tue Jan 15, 2008 8:15 pm
buy a storm kit there the best imo and there a bit of a fiddle to fit under the scuttle i think its called a bit tight but its ok
as for the kit have a look on ebay for a storm kit this is what i have on my track car and can't fault it mate
YOU could even adjust the park so i gues you could have it parking in the middle (if thats your bag)
hth
tannerman8807
Tue Jan 15, 2008 8:24 pm
In this weather how about doing a triple wiper conversion ! winkeye
For sale soon, 325 Touring (H) 1991 Jan. Auto 104K, silver BBS (black and silver) Mint sport interior. New front wings, very tidy, all bushes done front and back, Wheel bearings. Available this month. Email for further
potman
Tue Jan 15, 2008 8:44 pm
thanks,
kit coming soon :D
kingcruizer
Tue Jan 15, 2008 8:48 pm
hello mate. ive done a single wiper on my cab. only abit of cutting and welding so save yourself some doller. start by taking the linkages out of the car. once out cut the drivers part off as this is no longer needed. make sure you dont cut any of the mounting plates off. then take the small bar off the motor and cut it on the bend. shorten that bar to 54mm for the perfect sweep. grind it smooth and replace the whole lot back in. you can have the wiper parked where ever you like, just take the bar off the motor move the wiper by hand to the position you want and bolt the bar back on.
take your time with it and it'll work out for you. hlh
see pics for sweep and measurment.
p.s use a straight arm off a ax or a bx
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
agreen
Tue Jan 15, 2008 9:01 pm
saving £90 - Good work :D
kingcruizer
Tue Jan 15, 2008 9:09 pm
it works really well. forgot to say, i used a spare seat bolt cap to blank the drivers side hole. just a dab of super glue, job done.
potman
Tue Jan 15, 2008 9:30 pm
thanks alot, thats a great help. i'll try that this weekend.
fuzzy
He who sleeps with "Gingers"
Tue Jan 15, 2008 10:04 pm
i fitted a single wiper on my chavalier runaround. the driver side wiper broke so i turned the passenger side wiper around slightly on its mounting and bent the arm a bit to sweep across both sides.
a botch job even munky would be proud off :D
OBs
Tue Jan 15, 2008 10:10 pm
A 'Sh1treon Picasso' has a good all plastic covered rear straight arm, come to think of it most french turds do...
Megan, 307 etc etc
But rig up the BX front arm with the washer jets and blank the bonnets off winkeye
bmwscorpion
Tue Jan 15, 2008 10:11 pm
Get a storm kit, 1 hour to fit at max.
You will not be dissapointed. :D
Dave_M3
Wed Jan 16, 2008 2:10 am
I like that idea King crusier.
I'll give it a go myself I think.
looks easy enough.
The seat bolt cap is a neat touch too :D
bottlecapE30
Wed Jan 16, 2008 4:21 am
i will never understand why the right hand drive cars have a different wiper linkage set up then the LHD cars.
1987 2.7l e30 m20b27 supercharging
1991 3.5l e30 m30b35 it is dead so sad
1985 3.5l e23 m30b35
bottlecapE30
Wed Jan 16, 2008 5:52 am
i found this on real oem the LHD linkage uses a 54mm arm stock all you need is to buy part number 61611370799
it is number 4 on this diagram
http://www.realoem.com/bmw/showparts.do ... g=61&fg=45
that would save all the welding and be bolt up.
another thought is to use the lhd vent to cover the hole that is not is use not sure of the part number on that one.
potman
Wed Jan 16, 2008 10:32 pm
thanks bottlecape30, luckily my best m8 is a bmw ceniour workshop tecnition (can't spell :cry: ), part on its way in 2 days.
good idea on the LHD vent cover. i'll get one of them too :D :D :D
potman
Wed Jan 16, 2008 10:35 pm
if u had a RHD wiper set on a LHD car, u would get the big unwhiped area that is on the n/s in ur line of vision.
hope that sounds right to readers of this.
12345kevin
Wed Jan 16, 2008 10:36 pm
bottlecapE30 wrote:i will never understand why the right hand drive cars have a different wiper linkage set up then the LHD cars.
Because the driver sits on the other side, maybe !!
bottlecapE30
Thu Jan 17, 2008 3:25 am
(slaps fore head ) da there i go typing before i think.
potman
Thu Jan 17, 2008 7:34 pm
