head light removal-legal?
jondrift
Mon Oct 08, 2007 7:49 pm
im thinking of removing the two lights closest to the grill in order to get more air to my nearly finished turbo setup. just wondering, is it an mot failure? which lights am i loosing and do i need to relocate the bulbs into the other lights at all?
jonathan
StuBeeDoo
Mon Oct 08, 2007 8:03 pm
I'm not 100% on this, but I think that the inner lamps aren't a legal requirement, but if they are fitted, they have to be working and aimed correctly.
Steve-E30
East Sussex Hooligan
Mon Oct 08, 2007 8:11 pm
You must have highbeam for a mot , Think someone mentioned putting early golf lights in replacement with th outer e30 lights as they have all the elements for sidelights , low beam and high beam so you can lose the inner lights , Im sure someone will correct me on what lights are used :D
Giggety Giggety Goo!!!
hennabm
Mon Oct 08, 2007 8:32 pm
As BMW see fit to put the high and low beam in separate lamps then to be legal your car must still have high and low beam, albeit combined. I remember there been a conversion for the E21 to make both in and outer lamps work on high beam for the 323 and 320 models.
CraigG
Mon Oct 08, 2007 8:42 pm
as said above, you can remove the light, but you have to convert the outer light to be both dipped and main, eg a H4 bulb format.
id imagine there are a few ways of doing this, but i couldnt tell you the best way to go about it, golf light sounds good, but size might be an issue.
fuzzy
He who sleeps with "Gingers"
Mon Oct 08, 2007 8:56 pm
the lights are easily removable so just keep them safe and refit them at mot time. theres a lot of plastic in the grill between the slats that can also be cut away carefully with a jigsaw and bigger holes can be cut out of your lower metal valance behind a tech2 kit if you have one. another option is air duct with directional piping in the lower valance.ive done those 3 things and kept the lights to keep the standardish look of the front end and have no cooling problems but my large twin cosworth electric fans help enormously and cut the temp from 3/4 to 1/4 in matter of minutes even in standing traffic. also a new or recon radiator also helps a great deal as your old one is bound to be clogged up after years of use.another option is air vents in the bonnet above the turbo pointing backwards to allow the hot air to flow out but if you do this a plate needs to be fitted under it to stop rainwater running in and onto your turbo,that quickly rusts up your turbo and causes lots of steam bellowing out at traffic lights winkeye
jondrift
Mon Oct 08, 2007 9:15 pm
ok sounds like i have a few options. i really need to do something as my intercooler is not front mounted, shame about loosing the standard look but i think i might have to! Ill have another think! thanks
jondrift
oh, and can anyone post some pics of e30s with removed lights? might help the descision...
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Mon Oct 08, 2007 9:37 pm
this is a pic of mine, had to remove the lights for the intercooler, looks a bit menacing i think... :twisted:
oze30
Mon Oct 08, 2007 9:50 pm
How hard to change from H1 to H4 bulbs?
Colonel Sanders
Mon Oct 08, 2007 9:52 pm
havent changed the bolts yet, as im in guernsy an have no mot
fuzzy
Mon Oct 08, 2007 10:00 pm
jondrift wrote:ok sounds like i have a few options. i really need to do something as my intercooler is not front mounted, shame about loosing the standard look but i think i might have to! Ill have another think! thanks
how have you mounted your intercooler? i was also considering getting a custom cooler made to fit in the void between the lights directly behind the grill and full height from bonnet to bottom of valance so i could then also use a full height rad as i currently use a 2wd cossie cooler that is quite small and sits on top of the rad. ive also seen folk use 2 inline 2wd cossie coolers on e30's due to space restrictions. i have quite a lot of space at the front of my engine as mine is a little short 4 pot winkeye
jondrift
Mon Oct 08, 2007 11:43 pm
that does look good! mine would look a bit more messy cos my intercooler isnt quite as sexy as that!
Colonel Sanders
Tue Oct 09, 2007 5:34 pm
i wouldnt suggest getting an intercooler as big as mine though unless you dont mind cutting out half the front valence..... mine is 32"x11"x3.25"
its too wide really, you dont wanna go over 2.5" wide or you have to start cuttin.
other than that it didnt take long to fit and its so jammed in there i didnt have to bolt it in, but i did anyway just in case..
zaust
Zone day release
Tue Oct 09, 2007 8:49 pm
CraigG wrote:as said above, you can remove the light, but you have to convert the outer light to be both dipped and main, eg a H4 bulb format.
You can use motor-bike light's. Honda, Suziki ect all have model's with the same diamiter.
And rossel, It does look very menacing. i like.
M30 Tech 1 Touring on gas.
ed325i
Wed Oct 10, 2007 8:31 pm
I am going to use something like this.>> http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=002
