doing the valves on an auto..I get stuck at step 5
djezd
Fri Jul 20, 2007 8:03 am
I attempted to check/adjust the valves on my 323i auto yesterday. However i got to the same point as I did a couple of years ago which is, turning the cam shaft! I can't!
The car is in neutral all the spark plugs are out and i simply can't turn it on either of the two possible attachments.
Has anyone had experience of this on their auto?
**BANNED**
Fri Jul 20, 2007 3:06 pm
22mm spanner on the crank?
Templ8e30
Fri Jul 20, 2007 3:14 pm
Try kicking her over on the starter, only quick bursts though. She won't fire up if you've got all the plug leads off.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Fri Jul 20, 2007 4:42 pm
daimlerman wrote:22mm spanner on the crank?
Nice long extended end on the bolt, thoughtfully provided by BMW for this purpose.
Try to remember to remove it when you have finished though!
**BANNED**
Fri Jul 20, 2007 4:48 pm
Comes off at speed,I find....
Fri Jul 20, 2007 4:50 pm
daimlerman wrote:Comes off at speed,I find....
It does, and with a considerable bang!
**BANNED**
Fri Jul 20, 2007 5:00 pm
You too huh :cry: :cry: !!
djezd
Mon Jul 23, 2007 10:49 am
I tried 8 ADAPTER 1 09/1985 11311276855 that got gnarl first time.
I tried this time 06 HEX BOLT M18X1,5X65 1 11231709037, which is the one i think you're telling to get a long extension on? the rad was some what in the way as it is with out any extensions.
I have basically given the job up on the basis of if it ain't broke.
cheers for the tips.
