325i overheated last night :O(
bri_on_1
Sun Mar 11, 2007 10:29 am
Last night i was driving home from my brothers house when the temp needle went into the red so i pulled over to find my car had no water left in it 8O My only option at the time was an empty bottle of water and a muddy puddle so i filled the car up to get me home. Well it got me back home (only 4 miles away) and the temp looked fine it was sitting at half way but i had no heaters at all. I took a look this morning to clean the crappy water out and replace it with clean water and coolant. When i was flushing the water out with a hose i saw water pouring out of the water pump area :cry: So what damage have i done :cry:
mrLEE30
Sun Mar 11, 2007 1:16 pm
best case nothing, worse case head gasket but you wont know till you get it running again
it seems obvious from your description that the water pump has gone and this is why you have lost your water.
so time to replace the water pump, and whiale you are there change the cam belt/tensioner
then fill it up with normal tap water, run it, bleed it and drain it, repeat three or four times or unitl the water draining out is clear, then fill with antifreeze/coolant, bleed the air out and see what happens, keep an eye on the water level to be sure there are no other leaks and hopefully this wil be the end of your dramas
mrlee
Sun Mar 11, 2007 1:55 pm
Very important that when you start the car for the first time after this that you have the heater full on, with the heater fan on about 2 and check that warmish air starts to come from the heater after a few minutes. Also watch the temp gauge carefully at the same time.
Air locks frequently occur after refilling a 325 cooling system, and can result in a cracked head.
bri_on_1
Sun Mar 11, 2007 2:06 pm
I have got a new head ready to go on at some time so i think i will do the head gasket at the same time as the water pump. This will be my first head gasket change i have done on any car so it should be fun :?
adamS
Sun Mar 11, 2007 2:14 pm
Hi there,
I've just done the HG on my 327. I'm not really that great with the spanners but found it quite straight forward!
Good luck mate :cool:
bri_on_1
Sun Mar 11, 2007 2:18 pm
cheers m8 i must be brave and think positive :D
mrLEE30
Mon Mar 12, 2007 6:36 am
dont forget there is a specific way to tighten the head bolts, this must be followed or you will warp the head and knacker it.
All manuals (haines and Bentley) show the correct proceedure.
