Lifting from the bumper mounts?
ross_jsy
Right guys, wondering if someone could help. Basically I am looking at buying these:
http://www.machinemart.co.uk/shop/produ ... -020110006
Because they have a decent height (610mm) however looking at jacks there isn't really much, if anything without spending silly money that will get to that height and definitely nothing that will fit under my car and achieve it. So I was thinking what about those farm jacks that landy types strap to the outsides of their chariots, something like this:
http://www.machinemart.co.uk/shop/produ ... -020110485
And then making a support out of box section or similar to bolt onto the bumper mounts, similar to how you would mount a shell to a spit, to jack up from. Now obviously they take the weight of a bare shell, but will they be able to support a car with engine etc (albeit stripped, weighing in around 1000kg's)?
Or alternatively any other suggestions? I essentially want to get the car as high as possible as I am going to be doing a lot of work on the underside, for as cheap as possible.
Ross
Ross
I know the rally cars had two hook / jack points attached to the bumper mounts, but no idea how much extra strengthening those ars would have had. Without a cage at least there's a long old body shell to sag if it's only supported from the very ends.
I must admit, it's not something I would be happy with on a roadworthy shell with all running gear etc.
cheers,
harry
harry
- **BANNED**
'Farm jacks' have a rising foot as the lifting element.
How about making up a cross member that will fit the cill lifting points at the front and a second for the rear lifting points.Then the farm jacks could slot into the outer ends?
Two things to consider with farm jacks from my practical experience of using them;
The operating arm is long,allow at least a metre for each jack.
The base is small,the one's I used needed to be bolted to chunks of 4x2 to make the lift stable and reasonably safe.
Youth is wasted on the young.
If it was a track car, and I was planning on regularly having to work underneath it I think I'd be going down the route a lot of rally cars do with a pipe inserted into the sides of the sills, ( like e36 original jacking points ) and an adapter on top of an axel stand to support it.
cheers,
harry
harry
This is what I have. It's a god send!
ross_jsy
I have been tempted (and seen Martin Pallot's build where he did the same), however I don't quite trust my fabricating skills to go hacking up my rot free cills just yet. Granted, it would be the best solution though.harry_p wrote:If it was a track car, and I was planning on regularly having to work underneath it I think I'd be going down the route a lot of rally cars do with a pipe inserted into the sides of the sills, ( like e36 original jacking points ) and an adapter on top of an axel stand to support it.
And idol, that looks great, however my first bigish job I am planning is swapping boxes and unfortunately that looks like it will get in the way
- Brianmoooore
Before I had a proper four post ramp, I used to attach a chain hoist, hanging from a I beam in a steel framed shed, to a cars tow bar and stand it on its nose.
- Contact:
As punishment? S&M styleBrianmoooore wrote:Before I had a proper four post ramp, I used to attach a chain hoist, hanging from a I beam in a steel framed shed, to a cars tow bar and stand it on its nose.
