Touring rear suspension
Cotty
- Hartge Crew
Tried to do a search on this but could not turn up anything.
Is it the suspension the same as the saloon/coupe. I would like to change the springs and shocks but donÔš't know if there is any difference with the touring rear. Was thinking of getting the Bilstine sport kit, but would like to know that it will fit before spashing the cash.
Was thinking of a 40mm drop front and rear.
Paul
325i touring 1992 J
Paul
325i touring 1992 J
Cloggy Saint
e30nerd
didn't the tourings all come with M'tech as standard?
pm9575
If you check with Motormec, you'll find the rear shocks are the same - there may be a slight 'poundage' increase for the spring rate, but unless you are hauling a caravan who can tell?
Tourings left the factory with Mtec suspension, harder rear springs, and aluminium front track control arms, though I've never come across one yet that still has them fitted.
320Touring
hi there!
Anyone got piccies of what the Mtech suspension on tourings should look like?(i'm noew to most things BMW
I just bought one with gen 87k on it, so wanted to see if its the original setup!
320Touring
320Touring
Nothing you can really tell by looking that I know of, but magnets shouldn't stick to the front TCAs.
320Touring
thanks for the advice will try it 2moro and report back- just one thing TCAs=?
sorry, i'm a touch dumb
AndyTouring
Track Control Arms
SeamanStaines
325i Tourings have the same suspension as the plastic bumper 325i Sport. But this just means the M Tech springs and some slightly better Boge gasdampers, not Bilsteins.
If you ordered a standard 320i/325i with sports suspension, you'd get the proper Bilsteins!
TCA is track control arm, or front lower wishone. It's the L shaped thing that secures the bottom of the front strut to the crossmember. 325i saloons and Tourings as well as M3's have alloy ones but most have been replaced with the standard steel ones. There's no difference in Geometry, they're just a bit lighter.
Touring rear dampers - now they're an utter joy to replace, especially the top mounts.
Karan
SeamanStaines wrote:325i Tourings have the same suspension as the plastic bumper 325i Sport. But this just means the M Tech springs and some slightly better Boge gasdampers, not Bilsteins.
just to add the alloy arms cost Ԛ£140!!!!! compared to Ԛ£40 for the steel ones!
Davenotouring
I just bought a couple of cheap dampers, with top mounts.SeamanStaines wrote: Touring rear dampers - now they're an utter joy to replace, especially the top mounts.
Are they hard to replace, we were thinking they were easyish?
What's involved?
BMW 328i Cab - Daily Slag
- Homo Hair
only hard if you have to separate top mounts from the dampers
Davenotouring
Sweeeeet.
SeamanStaines
The problem is access to the two 13mm nuts that hold the top mount to the body. You've got to remove the rear seat edges and loads of trim. A complete bastard and you inevitably drop one of the 13mm nuts as well.
Davenotouring
I've had all this trim and the seats out before when I changed the speakers/leather.SeamanStaines wrote:The problem is access to the two 13mm nuts that hold the top mount to the body. You've got to remove the rear seat edges and loads of trim. A complete bastard and you inevitably drop one of the 13mm nuts as well.
I'll be extra careful with the bolts!
Thanks for the advice Captain!
andyp
- True Old Skooler
ive just got rear shocks for mine today and aint lookoing foward to the top mount part of it.
shelle-smokeahama
dave they're a piece of piss to change. if you aint done them in an hour then don't even bother to tyr doin ya spark plugs!!!!!
as for the suspension, the shocks are the same the springs are different, will fit but as said b4 will sit lower coz they cant hod the waight as well.
shelle-smokeahama
aint done them on a cabby but top mounts are a piece of piss on the tourerandyp wrote:ive just got rear shocks for mine today and aint lookoing foward to the top mount part of it.
