im looking at buying a set of wheels for the e30 and there
16 x 7 with et 10 and im crap with offsets will these tuck like crazy and need spacers ??
plus i wana run it low for a while so im gna need rubber bands for tyres lol like 195 45 16 ???
cheers
wheel help/info please 16 x 7 et 10
They should look good with 195's on too
P.S. - The higher the offset/ET number, the more the wheel will tuck in, the lower the offset/ET number, the more the it will stick out into the arch.
aaaah nice one guys cheers i got the offset wrong tho its et.40 so thats gna tuck like crazy so will need to get some spacers me thinks
would a 40 - 60 drop be plently on those wheel specs im pretty info useless on e30's just getting back into it lol im a vw nut. ( bassicaly a german car lover
thanks guys
edit whats the et of the standard 15x7 bbs please ??
thanks guys
IMO you would want at least 20mm spacers for them to look good.
Should look good with that drop, 60-60mm would be too low IMO.
I believe it is ET25 but not 100% on that.
HTH
HTH
The 'universal' one's will cause wheel wobble, especially as you are going to be using quite thick ones, they do not sit on the hub well (being universal).
Hubcentric one's sit perfectly on the hub and work much better.
the mims on my car here are 16 x 7.5 and are ET38.
See pics below.
On the front I have 20mm hubcentric spacers, on the back are none. I have just got some 15mm spacers and am going to stick them on the front and the 20mm on the back.
See pics below.
- Boyraceruk
Also, without huncentric spacers it's a royal pain changing your wheels because you're holding the wheel on with one hand, the wheel bolt with another and your third hand is wobbling the spacer around to get it to line up.
