FRONT FOG LIGHT WORKS WITH A TAP
redror
Sat Jul 24, 2010 3:44 pm
Have a problem on my car, when i turn the fog lights on only the passenger side lights up but when you tap the drivers side it will light up and stay lit until you switch them off and back on again. Ive checked the connector to the fog itself which seems ok if a little tatty but there must be constant power if it works when tapped. please shed some fog light on this annoying problem
cheers
snakebrain
Sat Jul 24, 2010 4:31 pm
It's a connection somewhere. Get your multimeter out.. :D
TouringTash
Sat Jul 24, 2010 4:33 pm
have you been throwing water about?
Sat Jul 24, 2010 9:10 pm
More than likely the bulb has failed.
When you tap the light when it's switched on, the two ends of the broken filament probably touch. Current flows, a magnetic field is produced, and the two ends are held together by this until the power is turned off.
redror
Sun Jul 25, 2010 6:09 pm
brilliant Thanks for that, i recently swapped the light in question and the same problem is happening. im going to take it out and have a good look and clean up of it.
TouringTash
Mon Jul 26, 2010 12:08 am
If the same is happening with this light and the previous one it's going to be the connector or cable.
When you say light I take it you mean the unit that the lamp (bulb) goes in.
redror
Thu Aug 05, 2010 4:53 pm
i meant the fog light glass, i think i have cured it now by fiddling :)
