205 55 15s or 205 50 15s tyres
e301988325i
I run 15" bbs 205/55's rear and 205/50 fronts, Toyo t1r's and I rate them very highly!
I said:
e30topless said:
lock the wife in there
- **BANNED**
Correct size is 205/55 15.
Getting harder to find these days,so the slightly lower 50 profile will be significantly cheaper.
I paid Blackcircles about £130 for a pair of Toyo's in April.
I would be wary of running different diameter's front/rear,especialy on an ABS equipped car...
Youth is wasted on the young.
I just had 2 Toyo proxes T1R's fitted for £105 all in, Company is called Ablefit in Bristol, The tyres are excellent, very grippy and look rather sexy too ( in a rubbery type of way!) Size was 205 55 15's by the way.
- JWaller360
I've just fitted 205/50 T1Rs, the car feels a bit more nimble, little bit less wallowy, if that makes sense?
However, I was running 55 profile budgets before, which explains a lot.
If you can find the tyre you want in 55 profile go with that, 50 profile will lower your car by 10.3mm which will also mean a bigger arch gap (if your into the stance of your car) as overall the tyre is 20.6mm smaller than 55 profile.
Get the toyo's if you can, good tyres.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
- Homo Hair
- Contact:
All of those are more expensive though..pnd wrote:everyone on here seems to rate toyos i dont i have had seveeral better tyres on an e30 eg bridgestone potenza eagle f1's and now that these are unavailable vredstein sportrac 3's.
For the money Toyo's are pretty much unbeatable
toyo's are awesome!
