engine misfire when cold, settles when warm although still not full power and looses all power/struggles past 5k
changed the following;
-Plugs (new part)
-leads,cap and rotor - changed
-fuel filter - changed (new part)
-checked fuel pres reg by sucking on vaccum
-tested and cleaned up cps
-tested injectors(electrically) resistance test-fine and all are clicking
-AFM - changed
-lambda sensor - changed (new part)
-blue sensor - changed (new part)
im sure theres more that ive changed or tested but cnt think just now
shes running far too rich, dumping way too much fuel into cylinders resulting in excessive fuel consumption 10-15mpg on motorway run. not good!!!
any other options,ecu??
