lumpy idle and slow speed (20ish mph) kangaroo
Daz87UK
Mon Feb 22, 2010 8:20 pm
i've been told its possably the maf sensor... is this true? also if it is, is there a way to remove said maf sensor and possably go down the induction kit route?
cheers in advance guys
Daz87UK
Tue Feb 23, 2010 8:00 pm
please help :(
e301988325i
Tue Feb 23, 2010 8:22 pm
engine, capacity, year, any new parts recently, modified at all, well serviced car, mileage, etc etc????
I said:
e30topless said:
lock the wife in there
Daz87UK
Tue Feb 23, 2010 9:04 pm
wow... m20b20 1989 only new parts are to try n fix it but didnt, sparks, leads, dizzy, rotor, oil + filter, coolant flush and intake and fuel system clean out with STP + RedEx... very well services, 104k
the only thing it could be... mods wise, it has a big exhaust which i havent had time to remove. but i dont think its all the way back, i think its only back box, but maybe middle section max.
nothing else mod wise could cause any trouble, coilovers, brakes, strut brace, interior etc...
it has NOT got a chavvy inductionkit, standard box and filter...
davidt
Pompey Council 4 door deviant
Tue Feb 23, 2010 10:14 pm
Swap the air flow meter for a good second hand one it cured a similar issue on my car :)
Tue Feb 23, 2010 10:39 pm
One thing it won't be is the MAF sensor, since your car doesn't have one!
Has all the symptoms of an air leak into the inlet manifold, downwind of the air flow meter.
Check all relevant hoses, and that the rubber blanking cap is still present on the little stub pipe under the throttle body, almost touching the TPS.
Daz87UK
Wed Feb 24, 2010 8:06 pm
whats the difference in MAF and Air Flow... Mass Air Flow & Air Flow... just the mass? anyway... couldnt find and blacnking cap or a hole for a blanking capor a little stub pipe, every pipe leads somewhere relevant. i dont think there is an air leak, i think i have found and resolved all air leaks
Morat
Wed Feb 24, 2010 10:47 pm
E30 AFM is a Vane type described here in wikipedia
http://en.wikipedia.org/wiki/Mass_flow_sensor
Most people mean the hot wire type when they talk about MAF.
Daz87UK
Thu Feb 25, 2010 6:56 pm
tried air flow meter, not fixed it, so next ideas please? i cant find any air leaks.... im going mad here :-x :cry:
Daz87UK
Thu Feb 25, 2010 9:40 pm
argh! this is insane... i must have removed and cleaned 95% of the connectors in the entire car... even the damn fuel pump so its DEFINATELY not electrical fault. i give up, can somebody come fix it for me please... cash waiting :)
Neil_uk7
Thu Feb 25, 2010 10:27 pm
I'm no expert here but I have a similar problem. I'm going to test my AFM this weekend as I'm hoping that's where the problem lies. But as you say you've discounted that, have you checked the throttle butterfly? And cleaned out the throttle body? Also, my TPS wasn't working until I tried the fix from Brianmoore. Does yours click at idle? When did the problem start?
Boyraceruk
Fri Feb 26, 2010 8:34 am
Is it the engine kangarooing or is it driveline shunt? I.E. Do the revs go up and down or does the car just jerk?
hazd31
Fri Feb 26, 2010 8:39 am
i thought this was a common e30 chariteristic which could be solved by clutch control?
im gunna keep an eye on this one my car does it too!
bmbartlett
Fri Mar 19, 2010 12:53 pm
Did you solve your problem mate? I've got exact same issue
e30_ev0
Sun Mar 21, 2010 8:22 pm
as above me too! :(
Neil_uk7
Wed Mar 24, 2010 12:56 pm
me too!!
swllt
Wed Mar 24, 2010 7:59 pm
I cured this by just cleaning the earths on the drivers side front strut pillar-true!
got to be worth a try 5 minutes work, no cost.
Luxorbeige and proud of it!
