Hi everyone
Need some help. I'm looking to buy a full suspension kit for cheap and I know there are two different strut sizes. BUT how do I know what strut size I need for my car?
Any advice on where to measure from or how I can find out the size I need would be very helpful.
Cheers.
What Strut Size???
- Brianmoooore
Strut size is either 45mm ("lesser" saloons) or 51mm (tourings, cabs, iS and 325 saloons), and is simply the outside diameter of the front strut tubes.
Measure the diameter between the bottom of the the spring cup and the hub.
The springs and rear shocks would fit but not the front schocks.bedumon wrote:Cheers for the reply.
So with mine being a 316i would it be fair to say I have the smaller strut? If I bought a 51mm shocks and springs kit would I be able to fit it to my car?
You need a kit for 45mm front struts.
- Brianmoooore
Or better, get a pair of 51mm front struts (complete with vented disc brakes). All just bolts on.bss325i wrote:You need a kit for 45mm front struts.
Ali-bumble
I have a full set of 51mm front struts off a cab I just broke with discs etc PM me if you want them
Discs have very little wear, pads half done and the BJ's are fine
Yes, this would be better.Brianmoooore wrote:Or better, get a pair of 51mm front struts (complete with vented disc brakes). All just bolts on.bss325i wrote:You need a kit for 45mm front struts.
- All_Torque
So am I right in saying 51mm aftermarket front struts will not line up with hubs off a 45mm oem setup?
World E36..
- Brianmoooore
Hubs from a 45mm strut are the same as those from a 51mm strut (give or take an ABS ring), but are not REMOVEABLE without damage, so can't be transferred.
- All_Torque
Cheers for the reply - now am I being really thick here
but if the hubs on the 51mm struts and the 45mm struts are the same, I can't see why a set of 51mm aftermarket struts will not fit a car which has 45mm struts?
World E36..
What do you mean by "aftermarket 51mm struts" If you are referring to the actual shocks they are inserts and fit inside the struts thus 51mm shocks will not fit in 45mm struts. The front struts are nothing like an E36, you can't unbolt the hub assembly from the strut like on an E36 part.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
- All_Torque
^^Great that makes much more sense!
World E36..
