Ive found an s50b32 engine for my conversion but it only has the original ecu. is it possible to remove/bypass the ews system when I only have the ECU for the engine? Ive heard there is a guy on the forum that can do it but im not sure what he needs.
Cheers [/b]
S50 B32 no EWS....
I see, the guy has an ews kit and ecu from a zm coupe that I can get with the engine thats out of an m3 evo. im assuming they will work the same way? or can the ews be removed just using the original ecu for that engine for the above price?
