Alternative brake servos?
Ziggy
Thu Nov 05, 2009 5:11 pm
I suspect that mine is on the way out. Rather than replacing it with another the same, is there a worthwhile alternative that would provide slightly more assistance? Nowt wrong with the E30 setup when that's all you use, but jumping in it is a little frightning when you drive a more modern car every day! :mad:
Thu Nov 05, 2009 6:22 pm
Twin servo from an E34 or E32
Trise30rally
Tue Nov 10, 2009 4:50 pm
I have just been looking into these twin servos, I can get hold of an e34 m5 one. is the bolt pattern the same as the e30?
Ziggy
Tue Nov 10, 2009 4:54 pm
Oops, I forgot about this!
Tell us more Dan - which cars are suitable for plundering, what's needed to fit, how big are they, how much more assistance...?! :mad: :cheers:
Tue Nov 10, 2009 6:28 pm
loads more assistance, they fit straight on. Google it, they do this in other countries as cheap brake upgrades
Ziggy
Wed Nov 11, 2009 12:16 pm
Looks promising, but I've only managed to find bits & pieces about it so far... Annoyingly the most promising suggestion seems to be that an E32 735i servo & MC are a good combo - I kinda hope the ones that I scrapped on an E34 535i wouldn't have worked!
Do you have any links Dan? & do you know if it's usually done with the E30 or E32/34 MC?
Cheers :thumb:
Wed Nov 11, 2009 6:57 pm
The forum seems to be unavailable at the moment
http://www.bmwclubmalaysia.com/forums/s ... hp?t=14194
Here is a pic of one in place
Daf318is
Wed Nov 11, 2009 9:09 pm
What is the rest of your brake system like? I drove a brand new vaxhaull Insignia the other day ( :o: ) and the brakes were shocking compared to those on my E30.
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Wed Nov 11, 2009 9:18 pm
What, worse? :eek:
Daf318is
Wed Nov 11, 2009 9:24 pm
DanThe wrote:What, worse? :eek:
Yup, E30 will stop fairly quickly but I was seriosuly unimpressed with the stopping power of the "car of the year". To be fair it was so slow it didn't really need brakes! :)
bimanut
Wed Nov 11, 2009 10:44 pm
not knowing much about conversions,
looking at it spose it wont fit in an m50 conversion even if it was moved over a bit?
Wed Nov 11, 2009 11:06 pm
Don't mistake a bigger (diaphragm area) servo for a brake 'upgrade'! It will do nothing for the brakes whatsoever, other than reduce the pedal effort for wimps.
Serious racing machinery has far better brakes than any road car, but pedal pressures of up to 100kg aren't unusual.
The E30 was designed in an era when women (alledgedly) still knew their place, very little thought was given by car designers towards making their cars female friendly, and the pedal weight was chosen by BMW to be the optimum that public opinion at the time demanded.
In these more enlightened times, car design is aimed much more at the female half of the public, as well as the elderly, etc. and pedal pressures have been reduced accordingly.
Jon_Bmw
Dangerous when thinking
Thu Nov 12, 2009 11:35 am
Never drive a Zafira after any Bmw. 8O
