larger brakes
Hi i have a 320i that i have used for track days and a couple of races, at the moment i have striped it down and i am puting a 2.5 engine in, i would like to put larger brakes on but not sure what would fit, does a e36 have larger brakes and would they fit on ok ? any advice would be great many thanks
hongkongfuey
- Mad-tango-geezer
would be intrested to know this too, also what size discs are they???
with cars like mine,
I have got the calipers and the discs for the front but not had time to fit them yet. Didnt know about the e46 rears.
What m/c are you using chriskkk?
info here
http://www.e30zone.net/modules.php?name ... ke+upgrade
info here
BadDave
the G60 disks are 280x22 and should be 4 stud.renoops67 wrote:looking in the book bmw discs are 260 x 22mm the g60 discshongkongfuey wrote:would be intrested to know this too, also what size discs are they???
are 280 x 22mm, just not quite sure if they go straight on
The centre bore needs increasing by 1mm and you also require a 2mm spacer between the hub and the disk
The RX7 caliper isn't a straight bolt on job,it does require a caliper bracket made up, but it's pretty straighforward to make one.
The E46 disks mentioned will be 5 stud, so will need re drilled to match the E30 rear hub(4x100mm).
IIRC you can use a std BMW handbrake setup with those.
There are a few different options listed over on www.300mm.de
HTH
The G60 disks are 4 stud but as mentioned you need a lathe to take off a very small amount to increase the hole in the middle. I did not need a spacer between hub and disk but machined a bracket using a drawing off the internet, bascially you offset the caliper. Its very very easy for the front brakes, the rears however had me swearing a bit.
The rear disks on a e46 320D are vented which is why i chose them, they also keep the handbrake intact , re-drilling with a hand drill needs huge patience to make sure the holes are correct, i used a dial guage to keep checking for eccentricity. The calipers i used were also 320D but they are heavy and i would have preferred to use some alloy ones but was in a hurry. The calipers do not just bolt on you will need to fabricate a bracket and weld it onto the rear arm.
Using larger 730i MC
Hope this helps
Hope this helps
If it helps anyone I've got the 280mm G60 discs pre-machined to fit E30 on the shelf - drop me a PM if you need some!
Ah shucks!DanThe wrote:I have the WMS 4 pot kit which uses G60 disks, they work very well
e301988325i
Keri, do you have any of the 2mm spacer plates for the g60 discs in stock?? How much inc delivery to please
I said:
e30topless said:
lock the wife in there
Yup, 2pr of them!e301988325i wrote:Keri, do you have any of the 2mm spacer plates for the g60 discs in stock?? How much inc delivery to please
£19.20+vat/pr + £2.00+vat p/p = £21.20+vat (£24.38 all in)
Hope that helps!
hongkongfuey
- Mad-tango-geezer
are 5mm spacers too big ??? I have a pair of them if anyone wants them???
