Ant how do you mean the accelerator pedal will break?
Remove the wing, carpet and accel pedal (it will break , so get a new one p/no: 35 41 1 156 488 ) , the loom will unclip and pull out of the way easily enough
Where abouts is the loom? I've the panel under the steering column of as well as the the light adjuster. Didn't notice any other wires.
I'm assuming this is do-able without removing the centre console to get the carpet enough out of the way for cutting, welding and painting etc?
I'm doing a bit of crash repair to the driver side. Wing and wheel was of when decided to poke around.
Would the car being a touring make a difference to it being double skinned?
I think my brother is using .8mm for his mini, will be using that (and him to weld
I'll try and take pics when I tackle this, have a front panel that needs clear coat, and a bonnet, wing, bumper and valance to prep for paint
