5 stud convertion
G4FUS
Thu Jun 25, 2009 2:21 pm
can any one help i wish to do the 5 stud convertion on my E30 what car is best for dona many thanks
SPADGE
Thu Jun 25, 2009 2:29 pm
G4FUS wrote:can any one help i wish to do the 5 stud convertion on my E30 what car is best for dona many thanks
E30 M3 :D
N00b
Thu Jun 25, 2009 2:45 pm
Apart from allowing for a better choice of wheels, what other reasons are there for doing this?
nickso
Thu Jun 25, 2009 6:32 pm
wider track, better brakes.
'88 e30 328i M52 track bint.
N00b
Thu Jun 25, 2009 7:05 pm
nickso wrote:wider track, better brakes.
Ah, so you must use the whole setup from something like an e36?
nickso
no, e30 m3 suspension setup has all those.
N00b
Thu Jun 25, 2009 7:25 pm
Surely that must be hard to come by though?
nickso
Thu Jun 25, 2009 7:33 pm
N00b wrote:
nickso wrote:
N00b wrote: Ah, so you must use the whole setup from something like an e36?
reasonably difficult. they pop up from time to time on here.
doc323
Thu Jun 25, 2009 8:32 pm
I saw a complete set of m3 suspension including discs on fleebay last week , it went for £495.
Theo
Thu Jun 25, 2009 9:39 pm
doc323 wrote:I saw a complete set of m3 suspension including discs on fleebay last week , it went for £495.
Those were just the fronts
doc323
Fri Jun 26, 2009 12:32 am
Yes it was :)
Dave_M3
Fri Jun 26, 2009 12:38 am
I saw a set of M3 hubs and struts for something like 50 quid on ebay abit back and there were no bids!!!
listing was ended when I found it so tried emailing the seller but no reply :(
E30-830
Tue Jun 30, 2009 6:02 pm
Can u do the conversion using the bits from an E36 Compact??
Do they not hav the same rear set up as the E30s only 5 stud?? :?
jaistanley
Tue Jun 30, 2009 6:09 pm
:banghead:
owenbach
Tue Jun 30, 2009 9:03 pm
yes i read that e36 318ti compact trailing arms will fit.and e36 front struts with adjustable top mount to set correct wheel camber.
dips346
London Meets Main Man
Tue Jun 30, 2009 9:10 pm
owenbach wrote: e36 front struts with adjustable top mount to set correct wheel camber.
wrong
owenbach
Tue Jun 30, 2009 9:22 pm
wot parts are wrong cos im thinking of same conversion.dont wont to waist my money on useless parts
Dave_M3
Wed Jul 01, 2009 1:24 am
It's caster you need to worry about mostly...
E36 M3 Evo wishones as well as Eccentric CAB bushes, offset topmounts and M3 Evo hubs are nearly right but still not quite perfect.
Best setup for the back is either E30 M3 hubs on the original trailing arms or else Z3m arms
