Hello all,
Can someone tell me what light bulb I require to replace the blown one in my dashboard analogue clock? Is it the same as the ones for the instrument panel?
Also I have a myserious switch in my dashboard in the bank above the head unit. I have the usual hazard lights, rear wind screen heater but then the the right of that I have a blank swtich which pushed to toggle and has a red line around it when it is in the out position. It is wired up but does not appear to do anytrhing. Does anyone have any ideas what this is?
Thanks as always.
NB
Interior Light Bulbs and Dashboard switch
gooner1
- Out humping Reindeer
Electric window cutout switch Nb.
NMB
Ah okay. Thank you for the crazily quick reply!
smithy318i
Hello.
The switch above the radio is a breaker switch for the electric windows.
As for the clock bulb... I believe it's a standard 1.2watt T5 12v (286) Capless Automotive Bulb 62111368299
NMB
I've just taken a look at the bulb and it appears to be fine but it had nothing connected to it. Is the bulb powered seperately from the cable to power the clock?
NB
NB
Grey/red and brown/white power the clock bulb.
