front drop link poly bushes
bodger
Sun Mar 29, 2009 1:22 pm
is there a poly bush available to replace the shitty rubber ones in the front suspension drop link, they seem to last six months then fall apart, i did drop the car back on its wheels before tightening the bolt but they still seem to tare :x
maxfield
Sun Mar 29, 2009 1:33 pm
Front droplink?? As in wishbone?
Or ARB droplink?
bodger
Sun Mar 29, 2009 1:36 pm
sorry, arb drop links :)
maxfield
Sun Mar 29, 2009 1:44 pm
Can't say I've ever really seen an upgrade for them..
Although I think you can get rose jointed ones but are pretty expensive.
DaveD
E30Zone Wiki Specialist
Sun Mar 29, 2009 1:47 pm
bodger
Sun Mar 29, 2009 1:52 pm
cheers fellas :D
Sun Mar 29, 2009 2:12 pm
IIRC, there's a link from a 5 series rear suspension that has a ball joint on both ends, and can replace the E30 link, with the addition of a little L shaped bracket for the bottom end.
monkey
Mon Mar 30, 2009 10:58 pm
Image i found these to work well and no bushes to fall apart . the links are mondeo estate 2000/2001 rear roll bar links think they where about £10 or so each .
murran
Tue Mar 31, 2009 12:39 am
you can buy the standard m10 rose joints and spacers for around £20 on ebay. chop the bush off the bottom of the link and thread the shaft and screw the rose joint on with a nut to lock it on. sorted.
http://cgi.ebay.co.uk/M10-Female-RH-Thr ... 240%3A1318
http://cgi.ebay.co.uk/M10-METRIC-Misali ... 240%3A1318
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
bodger
Sun Apr 26, 2009 11:27 pm
got chance to do these today, obviously got a pair of bushes but fitted one then remembered to take some pics of the second one
found this tool years ago, new it would come in for something
old bush
pressing old one out, i found a slice of the bottom of my axle stand to be the perfect size
new one going in
sleeve going in
all done
and fitted
bodger
Mon Apr 27, 2009 12:33 am
forgot to say thanks to daveD for the heads up on the bushes
DaveD
Mon Apr 27, 2009 8:53 am
ta ...I knew that link would come in useful one day! you will have to let us know what they are like on the road>
bodger
Mon Apr 27, 2009 10:43 am
DaveD wrote:ta ...I knew that link would come in useful one day! you will have to let us know what they are like on the road>
no probs dave, tbh i wont get the full benefit as there on the e36 as they needed doing for the mot on wednesday but after a run out in it yesterday i can tell there is an improvement, a lot less roll on fast bends. i will be getting some more for my e30 now, cheers
mhuk
Mon Apr 27, 2009 2:31 pm
monkey wrote:Image i found these to work well and no bushes to fall apart . the links are mondeo estate 2000/2001 rear roll bar links think they where about £10 or so each .
I got some to go on. I'll update you when it's done. Cheers
Triumph Spitfire MKIV
BMW E30 325i 4dr rightness
SUbaru Justy Gen2 AWD
mike_sayer
Mon Apr 27, 2009 2:35 pm
murran wrote:you can buy the standard m10 rose joints and spacers for around £20 on ebay. chop the bush off the bottom of the link and thread the shaft and screw the rose joint on with a nut to lock it on. sorted.
Have you done this murran? Does it work well? Any problems? Sounds like it could be a good solution with decent cost effectiveness!
"And if you are clinically insane, by which I mean you wake up in the morning and think you are an onion, here's your car." - Clarkson
mhuk
Tue Apr 28, 2009 3:41 pm
Fitted without a problem. Car feels firmer now. The driver side 'old' was not even bolted up when I went to remove!
Tue Apr 28, 2009 9:08 pm
Any idea of the Ford part number for these?
bodger
Tue Apr 28, 2009 9:23 pm
i just couldnt bring myself to fit a ford part to my bmw :teehee:
Tue Apr 28, 2009 10:15 pm
A grinder should deal with that, if it does have Ford markings.
There's also a 5 series rear suspension part, IIRC, that is similar in length and shape to the E30 link, but with a ball joint on each end. This needs a small L shaped bracket to be fabricated to fit it to an E30 arm.
town325i
Wed Apr 29, 2009 10:17 am
bodger wrote:got chance to do these today, obviously got a pair of bushes but fitted one then remembered to take some pics of the second one
old bush
new one going in
sleeve going in
all done
and fitted
im not being funny but i personally would of used new drop links to put new bushes into
DaveD
Wed Apr 29, 2009 10:54 am
err why would you do that ...its the bushes that keep getting sh****d and new drop links come with new bushes which are OK if they are oem at £60/pair but ecp ones wear out quickly so replacing the bushes is one cheaper alternative
town325i
Wed Apr 29, 2009 1:24 pm
DaveD wrote:err why would you do that ...its the bushes that keep getting sh****d and new drop links come with new bushes which are OK if they are oem at £60/pair but ecp ones wear out quickly so replacing the bushes is one cheaper alternative
well the ball joints wears out too so why use old ones and put expensive bushes in worn out parts. its like put new track control arm bushes on old worn out track control arms!
abelai
Wed Apr 29, 2009 3:22 pm
You have a point, but they are so easy to swap into new ones later I don't think it matters.
If I can't fix it I'll f**k it up so bad nobody can!!
bodger
Wed Apr 29, 2009 4:14 pm
the links i put the bushes into are only 6 months old, when they wear out i will change the bushes into another used set of links as the balljoints rarely fail before the rubber bushes, the poly bushes were not expensive they cost the same as a cheap set of links from euro crap parts
DaveM42
Wed Apr 29, 2009 4:31 pm
That is useful to know, so there is a use for wrong wheel drive Fords after all :)
aj_mckay
Wed Apr 29, 2009 5:17 pm
Bodger - Stick that write-up in the Wiki :thumb:
town325i
Wed Apr 29, 2009 5:59 pm
bodger wrote:the links i put the bushes into are only 6 months old, when they wear out i will change the bushes into another used set of links as the balljoints rarely fail before the rubber bushes, the poly bushes were not expensive they cost the same as a cheap set of links from euro crap parts
that sounds fair enough to me
bodger
Wed Apr 29, 2009 7:49 pm
aj_mckay wrote:Bodger - Stick that write-up in the Wiki :thumb:
not sure how to mate, feel free to stick it on wiki if you like :D
murran
Wed Apr 29, 2009 11:36 pm
yeah, i did it on my touring. was fine.
only problem is needing a tap and die set to thread the shaft on the drop link.
ed325i
Thu Apr 30, 2009 2:32 pm
Theo
Thu Apr 30, 2009 4:00 pm
Don't get cheap rose joints though, I bent the ones I fitted to my track car!
