Biggest wheels on an e30?
mrLEE30
18's with extreamly stiff springs i will wager!!
16's are the biggest you can go without modding the suspension, bigger than this you must stiffen the suspension or the rear will rub under compression and the fronts will rub while turning.
mine were 18's with standard shocks n springs, no issues ...mrLEE30 wrote:18's with extreamly stiff springs i will wager!!
16" are really the best for the e30 , 17" upwards really need some work doing and/or extra care when driving.
I had 17"'s on my old cabby for a while and they were a nightmare.
Felix79 aka Dan
E85 Z4M Roadster
E85 Z4M Roadster
Yup 16's are the best compromise, 17's start to cause handling concerns on the road, 18+ just silly in terms of bad handling characteristics and modifications needed. You will need body and suspension modifications if lowering and wish to run 17's. Unless you don't give a crap about sh1te choppy handling and rubbing arches? Elf runs 20's on his E30 but it looks comical (in my opinion)
Hey each to his/her own though- if you want the look then go for it, it's your car
16" or it will drive like sheeet
17" is fine ,,
but i think 18" will be to much
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
GrindCulture
Not in E30s any more
LeonNewton
16 is max imo but 15 realy looks best.
Yer i am sorry for my bad spelling. i am dislexic and find it just as hard to read your posts as you do mine.
heh, that's wierd, my comment above was posted without seeing grindcultures post of a monster e30 which went up at exactly the same time
17s can look good, but is a lot harder to get right. most e30s on 17s look poop. any bigger and it'll never look right. 16s are pretty much the universal 'correct' size. the e30 is a fairly small car with shallow sides, with big wheels it tends to look like it's perched on top of them
cheers,
harry
harry
