Deadlock works on passenger door but not driver door ??
e30newbie
Sat Apr 18, 2009 8:11 am
Hi guys,
When I turned the key 90 degrees left on the driver's door, it will lock both doors and deadlock the passenger door. However the driver lock will not deadlock. I wonder what is the problem ?
blingsta
Boost Junkie
Sat Apr 18, 2009 8:33 am
im sure its gonna have to be door card off jobby to investigate..
e30newbie
Sat Apr 18, 2009 8:45 am
I did remove the door card but I have no idea how or what to look for ??
rmt
Sat Apr 18, 2009 7:51 pm
This is a common fault. The passenger deadlock is triggered from an electric switch on the driver's door lock. The driver's door deadlock is trigered mechanically by the 90 degree turn, when the lock wears it doesn't trigger the mechanical lock any more. If you keep doing this it will eventually decide not to unlock the driver's door with the key! Get a new lock barrel from the dealer. If you do a search on here there is plenty advice on how to change it and to make the new barrel fit your old key.
e30newbie
Sun Apr 19, 2009 6:16 am
Thanks for the advice.
Should I get the repair kit or the whole lock cylinder ?
rmt
Sun Apr 19, 2009 11:02 am
I don't know what is included in the repair kit. I bought a whole new barrel. It is the spring loaded arm on the end that wears and doesn't work properly.
