16x9 all round
trex
Tue Mar 31, 2009 9:25 pm
hi as it says above what do i have to do to the front
or do 16x9 go on ok on the front thanks
al
Tue Mar 31, 2009 9:29 pm
Depends on the ET of the alloy's. If too high then you will need to run a spacer
trex
Tue Mar 31, 2009 9:34 pm
so its nothing major then just put on a spacer and it will be ok
Tue Mar 31, 2009 9:38 pm
Yeah should be, although with the alloyd being very wide already, you may need to modify your arches (roll or flare them) as they might stick out too much
trex
Tue Mar 31, 2009 9:40 pm
ok cool thanks for the help
Tue Mar 31, 2009 9:42 pm
No problem :thumb:
I have 9J alloys fitted to the rear of mine, ET is 15 which is about right 8)
