another diff question
corkie
Fri Mar 06, 2009 11:42 pm
am i right in thinking these are the filler/drain plugs...? :o:Image
if so are they 17mm...?
cheers eoin.
e30
leeparkes
Fri Mar 06, 2009 11:54 pm
yes they are!
not sure on size though
corkie
Sat Mar 07, 2009 12:01 am
:thumb: think it may be the same as the g/box...they also look fookin solid :cry:
e30
tomtomiS
its a good idea to make sure you can open the filler plug on these before draining the oil out
stonesie
Sat Mar 07, 2009 12:07 am
They need a 10mm allen key, the socket type is best that you use with a ratchet.
Un-do the top one first, you would be slightly pissed off if you drained all the old oil out then couldnt get the filler plug out :wink:
It has happened before i bet.
If you dont have one then a good ballance of price and quality is the Halfords Professional range, they have a lifetime warrantee so if you break it you just take it back and they give you a new one no questions asked... I'm on my 4th 36'' breaker bar 8)
corkie
Sat Mar 07, 2009 12:08 am
nice one tomtomiS,and i was going to do the drain first :o:
e30
leeparkes
Sat Mar 07, 2009 12:11 am
tomtomiS wrote:its a good idea to make sure you can open the filler plug on these before draining the oil out
Very good idea!
mrLEE30
Sat Mar 07, 2009 5:37 am
a good soaking with WD40 or similar thenight before, as mentioned dont use a right angle allen key use a proper sized allen socket as fitted to a decent wratchet bar, then before you attempt to shift it fit the allen socket in the filling plug (without the wratchet) and a good few hits with a hammer will ensure the allen socket is well in the plug and the shock will help loosen the corrosion.
mrlee
corkie
Sat Mar 07, 2009 12:18 pm
10 is no good mine is a 14mm and halfords only do up to a 12mm :eek:
e30
stonesie
Sat Mar 07, 2009 3:36 pm
http://cgi.ebay.co.uk/14mm-Hex-key-Sock ... 240%3A1318
Thats what you need, I have only ever seen 10mm plugs on E30 diff's though (untill now)
corkie
Sat Mar 07, 2009 5:56 pm
it may be that theyve been changed stonesie,anyway job done,wernt as solid as they looked :D :D
e30
