Remote Engine Start Alarm
Mon Mar 02, 2009 3:55 pm
Has anyone fitted one of these alarm systems to their car before? Are they worth installing? Easy to install or best left to professionals?
I've just been given one BNIB, just wondering whether it's worth installing.
TIA
Imy
Mon Mar 02, 2009 4:21 pm
would be good in the winter ecpecially if you drive a cab :P
i cant imagine it being too difficult all the wires will be under the dash
i'am sure mr brianmoooore will be able to sort you out with his knowledge :D
rubber_duck89
Mon Mar 02, 2009 4:24 pm
seems like a cool party peice...... the problem i wouls have with this type of gadget is once you have hit the button and the car is started what if someone gets in and drives off??
G104VHJ......Alpine White 318i Touring.....RIP
Mon Mar 02, 2009 4:41 pm
Car doors would be locked so no chance of getting in without breaking in :)
Mon Mar 02, 2009 5:21 pm
Having one removes CAT 1 or 2 status of an alarm
never knew that :o
punk_sy
Mon Mar 02, 2009 5:22 pm
I'm sure there illegal ? because the cars unattended and running!
Cook318IS
Mon Mar 02, 2009 5:25 pm
you shouldnt start it in gear either if its a manual. my mates cousin had a manual supra turbo with one fitted and started it with the remote start - with it in gear! went straight through the garage door :lol:
I've got the standard BMW alarm fitted.
Illegal? Never heard of that, my cousin had one fitted on his E30 many years ago :?
Mon Mar 02, 2009 5:28 pm
Leaving your car running without you in it is actually illegal yes!
Mon Mar 02, 2009 5:30 pm
Never knew that, would i get fined for having it fitted if i got pulled over?
Mon Mar 02, 2009 5:31 pm
No
Mon Mar 02, 2009 5:33 pm
Mon Mar 02, 2009 5:37 pm
But you will if you get caught using it.. :mad:
m666w
it's only illegal to leave a vehicle unattended and running on a public highway , so if you leave it running on youre drive it's ok ,
tomtomiS
Mon Mar 02, 2009 5:48 pm
back on topic they are not that hard to fit if you have any sense or wiring ability, there is so much scope for damage to be done if not properly installed. code alarm do quite a few alarms with the remote start function on. could be worth googling if you want to know more
Mon Mar 02, 2009 6:48 pm
Best left to the professionals then. How much would somone charge to fit one of these?
GrindCulture
Mon Mar 02, 2009 6:50 pm
Can I just ask, what's wrong with starting the engine with keys while you're sat in it? :?
Not in E30s any more :(
Mon Mar 02, 2009 6:53 pm
Nothing, it's a :cool: feature to have
aj_mckay
Mon Mar 02, 2009 7:45 pm
If it were me and I'd just been given one, I'd sell it. Simples.
Martinaston
Mon Mar 02, 2009 7:49 pm
Good gimik but a waist of time realy, you only use it on a cold morning or on a timer to start just before you leave for work but it just attracts attention to the car.
If you put it in you have to make sure the wiring is connected to the rev counter and the brake lights so as soon as the peddals are touched it cuts the engine. But when you climb in you normaly knock the pedals while your getting comfy so it cuts out anyway. :roll:
There is NO nucleus.
robbo86
Mon Mar 02, 2009 8:10 pm
Found this!
Regulation 107(2)(a). This states that no person shall cause or permit to be on any road any motor vehicle which is not attended by a person duly licensed to drive it unless the engine is stopped and the parking brake is effectively set. Exemptions to the requirements of this Regulation as to the stopping of the engine include a fire brigade vehicle, the engine of which is being used for any fire brigade purpose.
Martinaston
Mon Mar 02, 2009 8:13 pm
If you have a zinnobar then just stick a blue light on the top.
robbo86
Mon Mar 02, 2009 8:34 pm
Martinaston wrote:If you have a zinnobar then just stick a blue light on the top.
and block the road, rad always gets blocked when trumpton is around!
aceraf
Mon Mar 02, 2009 8:47 pm
Shouldn't really be used as leaving your car idling from cold is bad for your engine. I only wait for mine to switch to gas, and then drive straight off!
Breaking 325i Touring
Mon Mar 02, 2009 10:35 pm
I probably won't use it, just good feature to have is what i though. Looks :cool: with the mates :mad: :P
harry_p
Mon Mar 02, 2009 10:58 pm
i've got one, but not wired it in yet (and probably never will)
having read the instructions it's quite clever, there's no chance of leaving the car in gear. the one i have you have to put the handbrake on, press a button on the fob, remove the key (engine still running) get out, close door and set the alarm.
the remote start function won't work unless you do the above when leaving the car.
i'd only ever use it for starting the car up to defrost while i eat my breakfast on winter mornings, or 5 mins before i clock off from work on a late shift.
cheers,
harry
miniblob
Tue Mar 03, 2009 10:11 am
I had one on my 8 series!!! Very nice feature to have in the winter!!!!
Not illegal to have it - may be illegal to leave the car idling on the street, not sure, didn't bother me!!
Some people say it's bad for you're car to leave it idling, some say it's good to leave it idling for a couple of minutes - some don't care!!!!!!!
Shouldn't be able to start it in gear, unless it's not installed correctly (or has been fiddled winkeye ) - my one had to be set when you leave the car, i.e when you park (engine in neutral, handbrake on) you press two buttons on the fob, take the key out and the engine stays running, shut the door and when you hit the button to lock the car, it switches off the ignition!! Therefore guaranteeing it's in neutral when you start it remotely!!!
Don't forget to leave the heater set to warm and toasty :cool:
Oh, and mine was on a cat 1 - why wouldn't it be???
When started, the engine idles but the doors remain deadlocked. If you manage to get in, touch the clutch, without putting the key in first and it kills the engine (same even if you use the fob to unlock it - you still need the key in!).
I'll be getting remote start on the touring eventually!! I love it!!
Of course, there is nothing wrong with coming out after a long night shift, fighting a cold,stiff doorlock, opening the car yourself, scraping the ice off the windows and waiting in the cold for the mist to clear and the heater to warm up!!!
You'll have time to watch me step into my warm car and drive off!!!
327 Touring with bass!!!
Tue Mar 03, 2009 10:39 am
I'm thinking along the same lines mate, :cool: feature to have.
Going to get some quotes for installing it at the weekend :D
konfuzion
Tue Mar 03, 2009 10:49 am
miniblob wrote:
[ snip ]
[ snip]
It's an option (built-in or otherwise).
I spoke to the fella that installed my Sigma alarm about it. He also said it removed the insurance approved status of a cat1 alarm (amongst a few other personal feelings ;) ).
Much like if you or I fit a cat1 alarm. It's useless as far as the insurance approved status goes as you need a certificate from a qualified installer to do the job for it to be approved.
...or pressing a button to open the doors, inserting the key into the ignition and turning it Image
Regards,
Ian
Kingdoms are run by Kings, Dictatorships are run by Dictators, England must be a Country.
no2lurch
Tue Mar 03, 2009 10:58 am
[quote="ImysE30"]I've got the standard BMW alarm fitted.
quote]
would you have to remove the existing alarm before fitting?
Tue Mar 03, 2009 11:05 am
I'm not sure
robbo86
Tue Mar 03, 2009 11:52 am
I think a number of them are designed to work alongside any existing alarm, sure a load I looked at were like that!
no2lurch
Tue Mar 03, 2009 11:57 am
thing with my existing alarm is with the engine running, it dont do anything for toffee!
RUSHY
Tue Mar 03, 2009 12:39 pm
Mine was done at no extra cost from a friend who fitted My Clifford G5 (later Version)....to be honest i hardly ever use it......Its exciting to start off with, then u almost forget u ever had it fitted....
http://s187.photobucket.com/albums/x220 ... tart-1.flv
