Seem to be getting a lot of condensation in the boot. the car has been stood for a couple of months, but its made carpet go mouldy. Any suggestions to stop this? ive tried one of those small moisture absorbing boxes.
_________________
Condensation in boot of Cab--Now in right section !!
BMWAlpinaC2
Check the rubber seals, that's my best guess, where the vapour comes in from and then condenses.
Maybe a leak as pointed out as before, never know. Get more info and someone more knowledgeable on these things will come along.
My guess is, either a leak, or check the rubbers.
Hope it helps mate!!!!
this happens on mine, if its facing downhill watter fills the channel and the boot gets condensation in it. if i park it facing uphill it doesnt happen!mrLEE30 wrote:is the car parked by chance facing down a slight incline? if so it could be water running into the channel around the boot lid, then over flowing into the boot.
- E30 Zone Meets/Events Team
- Contact:
Mine used to do this and found it to be the rear light surrounding gaskets, now better after they were replaced
