starting problems
E30_Aza
Wed Nov 05, 2008 5:04 pm
hi guys, i wonder if anyone could help. most of the time when i go to start my motor nothing happens appart from what i would describe as a single tut from the engine when the key is put around all the way. dont know if this is an alarm problem as it is well fuct, or the starter motor.
can anyone point me in the right direction please?
aza
chumak
Wed Nov 05, 2008 5:36 pm
maybe it's ignition lock?
JAY1
Wed Nov 05, 2008 5:37 pm
flat battery...
JAY1
Wed Nov 05, 2008 5:38 pm
scrap that... i read your post too quickly!
E30_Aza
Wed Nov 05, 2008 5:56 pm
yeah great help!!!!!! i think not
Wed Nov 05, 2008 8:31 pm
Turn the ignition on as normal, but start the car by using a piece of wire to link pins 14 and 11 of the diagnostic socket under the bonnet.
This will determine whether it's a wiring fault or a starter fault.
E30_Aza
Wed Nov 05, 2008 10:30 pm
cheers brian, i will do that when i get a chance over the week end. i take it if it does start it is a wiring problem??
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Nov 05, 2008 10:35 pm
i recron its them 9js on the front, maybe u should swap with 2 of mine winkeye
E30_Aza
Wed Nov 05, 2008 10:38 pm
cliffybabe wrote:i recron its them 9js on the front, maybe u should swap with 2 of mine winkeye
go and find your own proper wheels fcuk face!!!! i do know where there is a set of 4 for sale
Wed Nov 05, 2008 10:40 pm
Is your car still an auto? If it is it could possibly be a fault with the inhibter switch which prevents it starting in anything other than P or N.
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Nov 05, 2008 10:44 pm
go and find your own proper wheels **** face!!!! i do know where there is a set of 4 for sale
if i remember corretly who called u and told u of them :x
already aware of the other ones,
E30_Aza
Wed Nov 05, 2008 10:49 pm
possibly mate, although me other mate who has a manual is having the same problem. always worth a look though.
Wed Nov 05, 2008 10:51 pm
check the battery connections are all secure, i've had this before.
